My episodes for this specific show are not matching the order that is used on thetvdb.
I have done The Plex Dance twice already. Not sure what I’m doing wrong.
Here are screenshots of the issue. You can see the order is not correct.
Any help would be greatly appreciated.
how are your files named?
what exactly is the file name for the “Where No Man Has Gone Before” episode for example
can you grab the xml for that episode
tom80H
3
it looks like you have configured the show to match based on the DVD order
https://www.thetvdb.com/index.php?lid=7&seasonid=13044&seriesid=77526&tab=season&order=dvd
check out Edit > Advanced > Order for your tv show.
Star Trek - TheTVDB.com
I didn’t think that was a possibility because I had performed The Plex Dance. Thanks for the help.
