Why can't I play TrueHD 7.1 directly through Android TV client?
Server Version#: 1.30.2.6563
Player Version#: Plex for Android TV 9.14.0.37895
TV: SONY XR-65X95J
I use Plex Android TV client to play TrueHD 7.1 audio movies are automatically transcoded to OPUS, showing that the device is not supported, but I can play this movie directly on the same TV using the Plex addon in Kodi, TrueHD 7.1 works fine, that means my TV supports TrueHD 7.1, why can’t I play it directly with Plex Android TV client?
I did try to change the “Passthrough” settings, but it makes it transcoded to AC3, AAC, never directly.
Kodi can use additional software to decode TrueHD, whereas Plex typically only can decode what the device supports, and Android TVs can only passthrough TrueHD through HDMI EARC to a sound bar or A/V setup, not decode it.
