Using Plex client on my brand new Samsung QLED QE49Q60R. I was expecting to work out of the box but I got lots of buffering. After an investigation I found that the movie is transcoding. Why is this? I thought in 2019 all the model support x265 even 10bit natively? How can i find the reason why this is transcoding?
General
Unique ID : 141658372491183121021728035837636430232 (0x6A9268FF49D9D1AB03236697B1E6C998)
Complete name : … 1080p.mkv
Format : Matroska
Format version : Version 4
File size : 1.86 GiB
Duration : 3 h 5 min
Overall bit rate : 1 431 kb/s
Released date : 1963-03-28
Encoded date : UTC 2019-10-25 16:11:36
Writing application : HandBrake 1.2.2 2019022300
Writing library : Lavf58.20.100
ErrorDetectionType : Per level 1
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Width : 1 920 pixels
Height : 752 pixels
Display aspect ratio : 2.553
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Channel(s) : 1 channel
Channel layout : C
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : -1 ms
Title : Mono
Language : Italian
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Duration : 3 h 4 min
Compression mode : Lossless
Language : English
Default : No
Forced : No
