Why plex no combine music in same albums? I have 3 pictures of same albums and can’t combined in 1 album?
possible causes could be:
- if you configured the library to use embedded metadata: typos in the embedded metadata where Album name or Album artist name deviate
- if you configured the library to use online metadata: file organization or naming
In any way you should be able to select all 3 albums (hover over a poster, click on the little circle in the top-left corner, then do the same for the other versions) and merge them (...
> Merge
in the library actions; see ...
in the top-right corner of that library, next to the “download” button and below the display style selector)
