Why wont folders open or allow me to delete them
Server Version#: latest
Player Version#: latest
Plex Media Server Databases_2018-07-11_15-15-16.zip (22 Bytes) Plex Media Server Logs_2021-01-30_11-22-41.zip (3.0 MB)
NAS had one folder which did work with previous win 10 laptop and cloud 3. Now cloud 5.
have reinstalled both server and player after deleting - have also removed localappdata / plex media server
can access the folders and files but they will not create a library that will open and cannot delete the libraries it tries to delete files but nothing happens
Not sure if you had your previous server installed on your Win 10 laptop or on the WD My Cloud. The current server is running on your My Cloud NAS. A Plex Media Server running on the My Cloud has some limitations – this is mostly about libraries being hard-wired to the automatically created media folders on your NAS.
From the support article on PMS on WD My Cloud Home:
Can I create my own libraries?
Yes and no. You can create libraries in the Plex Media Server. However, you cannot specify a custom location for the content. Instead, libraries will automatically point to the corresponding subfolder inside the Files area. So, place your television content inside the Shared TV Shows subfolder, music inside the Shared Music subfolder, etc.
Hi thanks for getting back - nothing in the set up has changed other than the make of laptop and the server going to cloud 5. I am not wanting a custom place for the library i want the original one to show up on the app - which it is not. I am unable to delete the library or seemingly set up new ones. Why cant I delete the library it is only something that is on Plex it is not on the NAS - that is what i dont understand.
The Library is a Plex thing so why cant Plex delete it - i know it is reading the NAS but it is not showing on Plex see screenshot .
This is the files and folder image on the server Plex is not there as is shown on the article you reference. Any ideas where to look?
From your logs, those libraries are linked to the following folders on your NAS:
  • /shares/Public/comedy/
  • /shares/Public/peel/
  • /shares/Public/all the rest/
I’m not 100% where those show in the NAS user interface.
That being said… the logs show that your library’s database is corrupted. This might explain why the PMS fails to delete that library.
Hi thanks again - yes its the Plex data on the NAS that i cant see and its not obvious where it is to a NAS novice like me
