Will there be a speed limit for Sever?
Server Version#:1.32.5.7349
Player Version#:1.75.0.3920-8b50876d
My media server is running on Windows 10. The player plays directly via remote without transcoding. Other software upload speed can reach 10MB/s, but the server upload speed is only 1-2MB/s. I don’t do any limit on speed, why is the server so slow?
What information is showing in the “now playing” tile for that playback on the Plex server dashboard? Is the stream listed as Remote or Indirect?
An indirect streams implies there’s an issue with your remote access setup and the stream has to be routed through a Plex Relay server – those connections are limited to 1 Mbps (2 Mbps for Plex Pass members).
https://support.plex.tv/articles/200871837-status-and-dashboard/
Exemplary screenshot from the "now playing" section
Edit: Also… please refrain from double-posting. Thank you!
https://forums.plex.tv/guidelines
What is the bitrate of the media?
If direct playing, Plex is not altering the stream.
You may see bandwidth spikes when the client buffer refills, but the average streaming rate will be the average bitrate of the media.
