It looks like your permissions are messed up on the folder, you should be able to run it form that folder if you change the permissions for the whole folder.
You are right, I guess I skipped over that part in the installation guide since I was eager to get it running. I uninstalled 3.3.2 and installed 2.7.5. It didn't work from my c:, I received the following error:
C:\Program Files (x86)\Plex\Plex Connect\PlexConnect-XML_templates>plexconnect.pyTraceback (most recent call last):File "C:\Program Files (x86)\Plex\Plex Connect\PlexConnect-XML_templates\PlexConnect.py", line 33, indinit('PlexConnect', param, True) # init logging, new file, main processFile "C:\Program Files (x86)\Plex\Plex Connect\PlexConnect-XML_templates\Debug.py", line 40, in dinitf = open(g_logfile, 'w')IOError: [Errno 13] Permission denied: 'C:\\Program Files (x86)\\Plex\\Plex Connect\\PlexConnect-XML_templates\\PlexConnect.log'But if I run it from a mount drive (Z:), then it works perfect. This is fine with me, just thought I would mention it for the others. Thanks for the help.
It's probably because you had it in program files. It's restricted to only be writable by admins starting from Windows Vista and even if you are an admin, you normally do not run programs with admin rights, so it couldn't create the log file.
Hi there, i'm getting some problems while i'm running on Windows 7. I read about this kinda of error, and it seems a permission problem. I run "cmd.exe" as admin and there's no way to avoid the error. Here's the log.
21:34:15 PlexConnect: started: 21:34:15 21:34:15 PlexConnect: *** 21:34:15 PlexConnect: PlexConnect 21:34:15 PlexConnect: Press CTRL-C to shut down. 21:34:15 PlexConnect: *** 21:34:15 Settings: add section PlexConnect 21:34:15 Settings: add option port_pms=32400 21:34:15 Settings: add option enable_plexgdm=True 21:34:15 Settings: add option ip_dnsmaster=8.8.8.8 21:34:15 Settings: add option ip_webserver=0.0.0.0 21:34:15 Settings: add option loglevel=Normal 21:34:15 Settings: add option enable_dnsserver=True 21:34:15 Settings: add option ip_pms=192.168.178.10 21:34:15 Settings: add option port_webserver=80 21:34:15 PlexConnect: IP_self: 192.168.25.8 21:34:15 PlexConnect: started: 21:34:15 21:34:15 DNSServer: started: 21:34:15 21:34:15 DNSServer: *** 21:34:15 DNSServer: Starting up. 21:34:15 DNSServer: intercept trailers.apple.com: 192.168.25.8 21:34:15 DNSServer: forward other to higher level DNS: 8.8.8.8 21:34:15 DNSServer: *** 21:34:15 WebServer: started: 21:34:15 21:34:15 WebServer: Failed to connect to HTTP on 0.0.0.0 port 80: [Errno 10013] Foi feita uma tentativa de acesso a um soquete de uma maneira que é proibida pelas permissões de acesso 21:34:24 PlexConnect: Shutting down. 21:34:25 DNSServer: Shutting down.
Read the troubleshooting common errors page on the wiki, it has a number of possible solutions for your port 80 error.
And most are caused by either missing exception on the firewall, or an AntiVira Solution intercepting http in order to "protect"
Added: One from the danish fora just had the samme error, and it was caused by either Skype or Dropbox that stole port 80
http://forums.plexapp.com/index.php/topic/73796-plexconnect-og-atv-3/?p=425705
/T
