WinTV dual HD with Nvidia Shield TV 2017
I believe I’ve seen different sources that has led to some confusion on my part concerning the use of these two devices with Plex Live TV. This tuner only works within a Windows OS, correct? Subsequently, it can not be used directly from a USB port on the Shield TV. Or am I missing something?
It will be able to be used in the Shield TV directly once their 5.2 firmware update comes out. You can join the Shield Preview Program to get early access to it.
Thanks Keith. I saw that requirement and promptly ignored it. Silly me.
