DVR not finding channels
Server Version#: Version 4.101.1
Tuner Make/Model: HauppaugeWinTV-dualHD Dual TV tuner
Using XMLTV?: yes
Good evening, I bought the HauppaugeWinTV-dualHD Dual TV tuner to watch TV on my devices through the plex. Unfortunately, when I connected it, I found out that Greece is not among the supported countries and I need an XMLTV guide to use it. Although with the wintv program from Hauppauge I can see all the channels normally, with the plex dvr and the XMLTV guide I can only see two. Can you help me?
Can only suggest you look at https://support.plex.tv/articles/using-an-xmltv-guide/
Presumably you are scanning a complete channel range ?
