WinTV-quadHD on Ubuntu 16.04 No Channels Found
I finally got around to installing this TV tuner in my server, and I went through the recommended PPA install procedure. When I rebooted Plex said that my TV tuner was detected. So I went through the channel scan procedure (antenna). However, I can’t seem to tune any channels. I have tried known working antennas, as well as the antenna I just wired for this project (it goes up to the attic, server is in the basement). I should be pulling down at least 6-10 channels with a dinky antenna. I can’t get any. I have tried all of my ideas to get this working, and I don’t know what to try next. Any help is greatly appreciated!
After trying out Ubuntu 17.10 I seem to have resolved this issue. However, I don’t see FOX (when its typically a strong channel on my TVs). Otherwise everything seems to be working well.
With Ubuntu 16 you have to install Linux PPA driver off Hauppauge support page
With either OS version I used this guide:
http://www.hauppauge.com/site/support/linux.html
Is that the one you are referring to?
Hauppauge Support | Running WinTV TV tuners and HD PVR 2 under Linux
Yes with Ubuntu 16.0x that was needed
Ubuntu 17.10 should have work out the box with out install any thing but with WinTV dualHD you need add the firmware.
