Wrong episode titles and data
Server Version#: 1.20.1.3252
Windows 10
I’m having issues with The tom and Jerry cartoon. Some episodes don’t have their correct titles even though the naming format is correct.
image image
image image
I’m not using local libraries.
Any idea how to fix it without doing them manually?
Make sure to use TheTVDB for this show, because TheMovieDB has only 10 episodes listed: https://www.themoviedb.org/tv/109452-tom-and-jerry
Click on the title of the show, which will bring you to the top level.
Use ‘Fix Match’ - ‘Search Options’ and explicitly select TheTVDB as agent.
Not sure what this means?
I’m using THETVDB, I even unmatched and rematched multiple times.
I meant that I’m not using the local media assets or whatever they’re called.
I had a similar issue and @ OttoKerner your suggestion above just worked for me. Thank you.
