Wrong TV Shows Posters
hello ,
a while ago few TV shows Posters changed to ( Janet ) poster and i don’t know how or what caused that , can someone help me with this plz.
PMS Version : 1.0.0.2261
Windows : 7 - 64 bit!
(/uploads/default/original/3X/b/1/b1dea86cbdfb62ceb8df42482767751147d56b6d.jpg “”)
While viewing the episodes of the TV show, can you click the three dots on the left hand side and select “fix incorrect match”? You should then be able to search and find the appropriate meta data you need to correct the poster for that season.
thats i know + when i try it now it dosent fix the problem and the poster dont change i have to do it manualy , but i want to know what caused this , the posters use to be the right ones but one day few of the tv shows posters just changed
That issue is most likely caused by an old favorite:
