When will the buffering issue on Xbox be fixed? If not, will you be refunding Plex Pass to those affected? It seems to be unfair to be paying for something that is unusable
Can’t watch anything at the moment as any file will buffer then play for about 30seconds buffer again. Wife is really pissed - not a good situation. I have the Xbox one x - everything was fine until about a week ago around the 7th May. Transcoding doesn’t do anything same result every time.
At this point I wouldn’t mind a refund. Feeling like I’m better served using my PS3 now.
So got mine to work by restarting the xbox. Maybe the Plex app has some sort of buffer over run problem therefore ram is getting chockers.
