I've just recently purchased Plex in hopes that I could stream through the xbox one. Thus far, I've only succeeded in having my xbox find the server, but nothing shows up in the library.
I downloaded the Plex app as well and it works perfectly on my iphone. So it seems the issue isn't server or computer side, but I'm at a loss as to what needs to be fixed.
Any help would be awesome.
Thanks!
DomC
November 28, 2014, 11:04am
2
A couple of questions:
- Do you have video libraries? The Xbox application doesn't yet support or show photos and music libaries
- Have you changed the settings of 'Weeks to consider in On Deck'? This is in your server settings. We have an issue if this is set to 0
- Have you changed the settings for 'Include in dashboard' for the libraries? This is visible if you edit a library
Hopefully one of those will do the trick, but let me know if not!
Thanks.
So the xbox doesn't support my music libraries? That explains it.
Any idea when that functionality will be coming?
I've also tried to get the music libraries to show up on my vizo TV with no success. Same story?
DomC
December 1, 2014, 4:15pm
4
Indeed. Both TV and Xbox apps are video only on their initial release. We're working hard to get photos and music into these apps soon!
Please let me know if there's anything else I can help with. Thanks!
Please put this "blank" library in the FAQ... It took me over an hour to figure out that XBONE Plex doesn't do music / photos.
system
Closed
December 21, 2019, 3:41am
6
