XPlay (Android)
Thank you.
Also I’ve found the description here:https://support.plex.tv/articles/201273953-collections/
I was doing verifications and it is the movies and series with audio dts 5.1a that happen to her, the others work correctly, before it did not happen, thanks.
I need an example of content anyway.
How do I pass the link ???
Archivos
El reino (2018) h264-1080p AC3-6ch.mkv
Media
Video Resolution 1080p
Duración 2:11:23
Bitrate 5946 kbps
Width 1920
Height 856
Aspect Ratio 2.2
Container MKV
Video Frame Rate 24p
Video Profile high
Parte
Duración 2:11:23
File El reino (2018) h264-1080p AC3-6ch.mkv
Size 5.46 GB
Container MKV
Video Profile high
Codec H264
Bitrate 5498 kbps
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 23.976 fps
Height 856
Nivel 4.1
Profile high
Ref Frames 5
Scan Type progressive
Width 1920
Display Title 1080p (H.264)
Forzado true
Codec AC3
Canales 6
Bitrate 448 kbps
Idioma Español
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Display Title Español (AC3 5.1)
Por ejemplo
Imo he ment the downloadlink, but anyway you said it only happens on DTS 5.1 Audio but in your example its AC3 5.1, not DTS 5.1
In this type of audio is when I occur or I put in configuration transcode or I do not have sound, 2 updates before I think it did not happen, thank you and excuse my ignorance and not know how to send them what they ask me.
with your info I’ve found a movie:
looks like File El reino (2018) h264-1080p AC3-6ch.mkv
That’s the movie, thank you and sorry, I do not know how to help better.
But with this the same thing happens
Records
IO (2019) h264-1080p AC3-6ch.mkv
Half
Duration 1:36:02
Bitrate 7867 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Container MKV
Video Profile high
Part
Duration 1:36:02
File IO (2019) h264-1080p AC3-6ch.mkv
Size 5.28 GB
Container MKV
Video Profile high
Codec H264
Bitrate 6843 kbps
Spanish Language
Bit Depth 8
Chroma Subsampling 4: 2: 0
Frame Rate 24 fps
Height 1080
Level 4.0
Profile high
Ref Frames 4
Width 1920
Codec AC3
Channels 6
Bitrate 640 kbps
Spanish Language
Audio Channel Layout 5.1 (side)
Spanish Title Display (AC3 5.1)
Codec AC3
Channels 6
Bitrate 384 kbps
Language English
Display Title English (AC3 5.1)
Codec SRT
Spanish Language
Spanish Title Display (SRT)
Codec SRT
Spanish Language
Codec SRT
Language English
Display Title English (SRT)
Okay, I try it little bit later and let you know what the result is.
Ok thank you very much already tells me, the strange thing is that previously worked correctly.
I’ve tried.
Everything works well.
I have sound in Direct play mode.
Well, I did not and it always worked for me, if I put external player it works for me.
What are your player specs?
I do not understand what it means, I have a video in Directplay and in HLS transcoding, when it’s a movie with audio dts or ac3 5.1 I can only see it transcode or with external player if it does not have sound, the other movies or series are played without problem.In the audio dts or ac3 5.1 if I put transcode looks and hears perfectly.
I asked what is your device?
As I remember it was MiBox 3?
X96 mini thanks.
I’ll check it on my old A95X tv box and let you know the result. I guess in one or two days
Thank you very much for everything that tv box recommend me ??? I await your conclusions a greeting.
