I don’t recommend you A95X.
It’s just an old tv box on which I’m going to test the app to check the issue with ac3 sound.
What do you recommend? I want to ask you for advice, thank you.
I like my Nvidia Shield. For me it’s enough
But other people can have different opinions.
I agree with @DironDir, the Nvidia Shield is just amazing piece of kit
Yesterday I released the 1.0.25 version.
Some changes in UI and bug fixing
Hi @DironDir, it’s great that your doing updates and bug fixes.
Would it be possible for you to list them on each update so we know what’s fixed or updated.
Hi @Gordon-R
Sure, I will write it.
the last release had:
- Exactly 7 posters in line when exploring a section (before were 6,5 and looked not good)
- fixed: audio track selection worked incorrectly in some cases
This is great work
Really appreciate all your hard work
Thank you for supporting
I’m just wondering…
Does it make any sense to adapt the app for smartphones? What do you think?
Also for better working with issues there is a bug tracker at Github.
Here is the link: https://github.com/dirondir/xplay-android
Also I’ve added the link in the first post
" This repository is empty."
Exactly
But you can add an issue if you have one on the “Issues” tab
Man i really appreciate this update. thank you
Is it possible to have collections be searched for(i tried and it only sesrch movies titles)? I have alot of Movies and it would make much user friendly to use search or maybe a filter feature
The 1.0.29 version has been released.
fixed: in some cases the subtitle selection worked incorrectly
improvement: search can work with collections now - thank you @jcandroid1982_gmail.com for pointing to the issue
Can you please make this available for the firetv and firestick
Hi everyone.
I think to do minimal adaptation for the app for smartphones.
Sometimes I see that people try to install this on their not-tv devices.
This is possible, but I need to get a firestick first for testing. I’ve tried to publish the app for the Amazon app store but something went wrong during checking the app by the quality team.
