XPlay (Android)
Why do you think so?
Tested the same file with xplay and official plex app and viewed the activity status on the plex server.
Hello. I’ve been using XPLAY since February 2017 and it worked very well… thanks for the job. But on october 19 (2018) I updated xplay on my lg tv and now when I pause the movie I can’t restart from that point. It always starts several minutes before.
Also, when I have a tv serie with more than 10 or 11 episodes, I can’t scroll to the end.
Today (December 3) I’ve updated the apk but it works worse :frowning: when I click on a mvie, it works…but if I click on a TV serie with several seasons, it doesn’t show the episodes. Only grey screen and this symbol on the upper left corner: “–>”;
I know you work hard and I like it. But I think I prefer the older version. It’s possible to return to that version? before october… I don’t know if it’s possible on LG smart tv
Thanks and Regards
Hello, I’ve just updated to the latest version on my LG TV 55SK9500PLA and I can’t see any difference.
It has the same bugs as before, including when you change the quality on the main posters and save,
it defaults back to the original % this only happens when tuning tv off and then back on so nothing saves and still no auto login.
Very frustrating, as it looked very promising until it got messed up in October.
Keep up the good work @bublikoff love your app, let’s hope it gets sorted soon.
I see, thanks.
I’m going to buy something with h.265 for testing/experiments soon. Will see
Here we discuss only XPlay for Android and, unfortunately, I can’t say a lot about LG version.
You can ask more details in appropriate forum
https://forums.plex.tv/t/xplay-webos/106434/4004
Yes, sorry I’ve also just downloaded the demo before buying and installed xplay on my Nvidia shield tv and again the posters and disable theme sounds don’t save.
The layout is the same as WebOS which isn’t liked much as the version before October 2018.
Ok, thanks
Thanks. I will check it.
What would you like to see from old design? What don’t you like now?
The left hand side big poster is much to big, also when you scroll movies it stops after so many and when you want to go further you have to select from the alphabet from the bottom which to me doesn’t make sense.
I would only use the alphabet to search named movies or tv shows.
Also I’ve only just noticed that the demo doesn’t play 4K content!!
Does it need to be purchased first? the hdr and Atmos doesn’t come up at the top right of the screen like plex does.
I’ve purchased xplay on WebOS which has a few problem at the moment, and as I have the Nvidia shield, I will purchase the android version if it will play my 4K movies.
No. the demo is a full version with a trial period (it’s not the latest at the moment)
doesn’t it play totally or play without sound or play only in transcoding mode?
I’ve seen only that direct play doesn’t work correctly with dolby atmos videos. I will fix this moment
Next updates I’m going to publish on Google Play. I guess it will be easier for me to work with updates.
I will write when I finish with publishing.
The version you can download now by the link in the first post I’m not going to update in future
thanks alo for the app and the efford. It’s possible to choose a different version of the app in LG webos? or it’s impossible to install a different one?
DironDir is responsible for the Android App, not the LG WebOS App.
aaah didn¡t know. I’m new here since yesterday :frowning:
I don’t know. WebOS is the totally different platform and I don’t work with it. I’m sorry.
Thanks for help :slight_smile:
It plays 4K content with sound, but it doesn’t trigger hdr and Truehd with Atmos.
Just checked and it’s transcoding both video and audio.
4K HEVC - H264 and TRUEHD - ACC.
Hope that helps.
Thanks. It’s exactly I desired to see
I’m starting to like this app more and more, one thing I noticed today and I’m sure it’s been covered.
  1. When playing tv show, it doesn’t run inline with plex. So if I open plex the tv show hasn’t changed even know I watched a couple on xplay.
  2. The next episode plays the same one. (repeats)
  3. Also on the home screen when I was watching smallville s06e15 when you click to play it plays the beginning of season 6 even has shows the name of season 6 ep15
  4. No tv theme sounds, even with tick off in settings.
