Yatse with Plex support
ok, thx thats it. Works great! PRoblem solved
I do not post all updates here but Yatse is monthly updated :slight_smile:
Yatse 8.1.6 is published
  • Changed: Applied new better internals to Addons / PVR and Files part of the application.
  • Added: Plex and Emby wizards now properly auto detect HTTPS mode and no longer require advanced settings edition.
  • Added: Sort by track number for Music Videos.
  • Fixed: Editing Custom Commands.
  • Fixed: Some issues with action bar title sometimes showing up when it should not.
  • Fixed: Artist name missing in now playing playlist.
  • Fixed: Remapped button left / right of volume auto repeat being activated.
  • Fixed: Workaround for one more JSON Kodi bug: Returning random strings for now playing items durations from RSS (Trac:17753 if anyone care at Kodi team ;)).
  • Fixed: Some reported issues and tons of optimizations.
Hello Tolriq,
Thanks for your work. Any plans of implementing a folder vice viewing option for Videos and Music? Or am I missing something?
Not sure to understand folder vice :slight_smile:
If it’s a typo then no folder browsing seems to not be possible with currently available Plex API.
Yatse 8.2.5 is now out with Free trials so anyone can test Plex integration :slight_smile:
dont support plex cloud?
I just bought the app and did not know it was not compatible
Plex Cloud was opened for a very short time before being shut down :wink:
If you can provide an account to that server in the issue on the Yatse tracker I’ll see what I can find out about it’s API.
A very much appreciated addition as this brings gapless playback!
Question; Is there any explanation why fast forward (skipping through an audio track) would not work? I can’t seem to get this working.
Without logs How to get debug information and open a proper issue it’s hard to tell :slight_smile:
Could be because there’s transcoding that encode to a format that does not properly manage seek.
Many thanks for the ultra quick response. Yes!! I noticed transcoding was on for cellular data. Switching to original did the trick. Very very happy!
any news for plex cloud?
I did ask you for an account on your plex cloud server you never answered.
As I said Plex cloud no more exists I have no way to test to see how it works, Plex does not really publish it’s API as I’m not sure they love other apps to the same things as the one who needs subscriptions.
Just saw Plex 7.0 and user reactions :slight_smile:
Maybe more users should try Yatse with Plex support :wink: As a 100% user driven developed software if things are missing just open feature requests :slight_smile:
Started new beta of Yatse that support direct Plex.tv login for easier server discovery and reconnect.
Could maybe helps with your Plex cloud, can’t do more since well you don’t participate :wink:
I can stream all media using cellular data, but can only download some content not all. it says HTTP error 400 - Bad Request. Any solution for this? On latest Plex server and Yatse 8.4.1 using a DNS to connect remotely
I’ve asked my crystal ball and it does not know :frowning:
So let’s do it old fashion: How to get debug information and open a proper issue :slight_smile:
Thanks for sorting that problem out on our email chat. Would it possible to set a limit to the download speed of the syncing downloads? The problem is that it is TOO QUICK. It maxes out at 13MBps but then I can’t do anything streaming/internet related while it syncs on my network
Seems that email notification were not correctly migrated :frowning:
For the moment there’s no way to limit speed since users asked for max speed sync :slight_smile:
Will see to add that to the TODO list but at very very very low priority sorry :frowning:
#Yatse 8.4.5 is published
  • Added: Support for Plex.tv login, for easier and automatic Plex server discovery and reconnection.
  • Added: Compiled and targeted for Android P. If you are running Android P beta’s and have issues please contact support.
  • Added: Better default views on click when using Global Search.
  • Added: New artist view fanart grid.<
  • Fixed: Fix Plex media downloads from cellular in some cases.
  • Fixed: Finally able to update some Google libraries after they fix most bugs. Should fix last performances issues on old devices. (Please report any layouts changes)
  • Fixed: Optimize + some fixes to detailed grid view mode.
  • Fixed: Small issues fixed and performance improvements.
#Yatse 8.5.0 is published
  • Added: Complete rework of the UPnP handling to use a new more efficient library.
  • Added: Rework wallpaper handling to hopefully work better on Android O+.
  • Added: Hiding left menu entries setting is now simpler and free for all users.
  • Added: Some advanced hacks to improve application startup time.
  • Added: Implemented some Kodi 18 things to speed up music sync (Require alpha 2 at least).
  • Added: Add pause and resume all options to download queue manager.
  • Added: Debug mode indicator in left menu, to remind users to disable it after issue resolution.
  • Fixed: Improve host wizard to properly handle HTTP 426 code to switch to HTTPS.
  • Fixed: Do not try to use Yatse Addon if it’s disabled.
  • Fixed: Now playing bottoms bars buttons auto repeat working again.
  • Fixed: Twitch sharing when not using Yatse Addon.
  • Fixed: Some other fixes and performance improvements.
