Thank you for adding Plex support to this great app. Are there any plans to support Plex playlists in Yatse?
There’s plans for that
Just so many things to do to also support Kodi with that
Hey,
I was wondering if you need plex pass to download your files via yatse?
No you don’t, but for the moment no transcoding when downloading as this was what was most asked
Hey,
I started using yatse yesterday. At the beginning there is no way to play any content from my plex server. But changing to Force UPnP everything works fine.
But the conection says that the cerficate from my server is not valid. And the conection type is HTTPS (No cert checks).
There will be a problem with this type of connection?
And thanks to add plex to this app.
Can you please contact me with logs?
The option Force UPnP is only relative to Kodi so should have 0 impact on Plex.
For the https, it means your server is using a self signed certificate. This does generate any problem about using the application, but it means that Yatse can’t validate the integrity of the server it’s talking too. So you are vulnerable to man in the middle attacks. But it’s not really related to Yatse, it’s general https way of working
Yesterday I untick Force Upnp and works like a charm (maybe it was too late to do that stuff)
Just only with VLC player at time to resume a film. Then say that the link is not playable. I think is more related to VLC because with MX player works fine.
Anyway, I will send you the debug, but at my return from holidays.
For the record Smart Sync works without Plex Pass as all Yatse features currently supported.
Version 8.6.0 is published
Yatse still needs your help to counter Google robots
If you own a blog or a website and are willing to talk about Yatse please contact us.
Or if you know a Googler that is not a bot and can actually answer other things than automated responses
- Added: Add new Smart Sync feature, to automatically download episodes and/or remove watched ones to your local device for easy offline watching during commutes without worrying about it. (Fully configurable per show or season)
- Added: Add new setting to limit downloads to Wifi only. (With auto pause when no more on Wifi)
- Added: Enabled Spanish language for AI voice commands.
- Fixed: Fix Yatse working in proxy mode in some sharing case.
- Fixed: Fix some UPnP discovery issues.
- Fixed: Fix Kodi 16 music sync.
- Fixed: Fixed MPC detection for Kodi 18. (Requires Kodi 18 beta 1)
- Fixed: Fix Media Player Classic custom commands.
- Fixed: Fix favorites sorting.
- Fixed: Update Google libraries to try to fix some rare crashes. (As always please report any bugs)
- Fixed: Fix streaming for Kodi versions that continues to ship with broken LibMicroHttpd…
- Fixed: Some other reported issues and always more optimizations.
#Yatse 8.6.5 released.
- Added: Support Fire TV as network player/renderer.
- Added: Added easy source library filtering, you can now apply global filter to each library category to only show content related to that source in your media center. (For Kodi, works better with v18)
- Added: Smart filters selection lists now includes filtering.
- Added: Get ignore articles list from Kodi 18 to support more languages. (Require Kodi 18 Beta 1)
- Added: Queue URI to API and Tasker plugin.
- Added: A few more details to albums/artists info page when available and new design for some info screens.
- Fixed: Next episode part in overviews could be missing sometimes.
- Fixed: Language setting not always working on recent Android versions.
- Fixed: First sharing sometimes not working.
Source library filtering for Plex users simplify a lot the navigation allowing to merge all the movies / shows libraries in one and easily filtering when needed.
#Yatse 8.7.0 released.
- Overview and home pages are now fully configurable. (Visible sections and order)
- New overview and home page design + many other design tweaks. (More to come)
- You can now hide tabs you never use in interface settings.
- Added support for new Kodi 18 option Use artist sortname. (Require Kodi 18 Beta3)
- Muzei support is back with Muzei 3.0 API.
- Option to show response for HTTP Custom Command plugin.
- Try to automatically fix some user input errors in wizards.
- Streaming Emby PVR from the EPG view.
- Workaround for Netflix plugin that returns wrong media types for shows.
- Many internals updated / migrated to Kotlin.
Does the app work with remote servers or only accessible to servers on the same home network? Thanks
Both cases are supported
Is there a way to hide certain video libraries from being grouped as movies, For example my porn movies are grouped into movies and show up on the overview, I would like that not to happen…
edit I found the source libraries button under the filter settings. whew. lol. Was in a shock after opening up the app after installing at work and all my Movies in progress popped up!
You can either use the filter, or edit the host and completely remove some libraries from the sync too so that they are never usable and visible on that device
Perfect thanks!
I just discovered Yatse had plex support today, and it made my day years ago when I moved from XBMC to Plex, yatse was one of the things I missed the mos. I was happy to see my old unlocker still worked. I threw a small donation your way. Thanks!!
I just unlocked the full version of Yatse to have Plex support but I cant do much with it.
I have Yatse on my android, Plex Media Player open on my PC and I want to use Yatse as a remote.
Here are the issues I’m having:
- When I try to control the media Player using cast, the player shows up as “Roku 3(4200X)”, don’t know why.
- When I connect to it (the roku device, that is) it controls my Player, on the PC, but the remote is very limited, only arrows + OK + return work out of the dozen present
- When I try to play ANY media while casting I get an error message saying “Problem starting media. Does your player supports the chosen file format ?.”
I can’t seem to get it to do anything.
Is this expected behaviour? If someone could help me please, thank you.
tl;dr : Only remote couple of buttons on remote work on Plex
Yatse for the moment is not meant to be just a remote for Plex clients, as plex clients are quite limited in that regard.
It’s mean to be a client to Plex Server that can cast media to multiple players.
So point 1 and 2 are normal.
Point 3 is not normal but as written a lot in this thread and everywhere:
Without logs nothing I can tell.
#Yatse 8.7.5 released.
- Many, many, many internal changes to prepare the future.
- Migrated to last Google In App billing library, please report any licences issues by contacting support.
- Fixed Kodi custom commands creation.
- Some music videos sorting issues.
- Some other reported issues and always more optimizations.
If you use Yatse for Plex and lack some functions, or do not use it because it lack things, please do not hesitate to make feature requests on web site to influence the TODO list order
Perfect app you have here!! I’ve been using it since 2012!
One question: is there support to play images/photos (I mean… with Plex as media server… because I know with XBMC/Kodi there is - at least since 2012)? I can’t find that option.
Thank you in advance.
Not yet as no one asked for that
and Kodi image side is really limited
Open a feature request at https://community.yatse.tv/ and see if more people want that.
