I imagine there are more people who want it, since Plex has a feature of family photos slideshows. And most folks use it for that.
#Yatse 8.8.3 released.
Merry Christmas and Happy New Year. A big thank you for your support since all those years!
- You can now press header of info dialogs to go to media lists.
- Fixed: Some rare Legacy unlocker issues.
- Fixed: Text selection in info dialogs.
- Fixed: Some covers display on remote players.
- Some rare crashes are now crushed.
- More refactoring and library updates.
- Some other reported issues and always more optimizations.
Do not forget to rate the application.
If you like this, please buy the Unlocker / Donate to ensure continued development.
I love your app and bought it twice for 2 of my Google account . Please improve search for plex to support artist and actor names.
On movie and TV episode detail page please include actor names that you can pull from tvdb and tmdb and so that we can click those to see all movie and TV shows by that actor
Please open feature request on the web site.
The problem is that Plex API does not allow to get that data during bulk sync and require 1 call per item and it’s very slow and inefficient
#Yatse 8.8.5 released.
If you are using Yatse on Android 4.x please join forums to give details about your usages (https://community.yatse.tv/t/survey-do-you-use-yatse-on-android-4-x-and-for-what-purpose/1362)
Some major libraries are moving toward Android 5+ only, so your information are important to delay (or not) the same requirement in Yatse.
- As requested by some users, you can now donate via subscriptions. Gives access to a private section on Yatse forum.
- Settings, hosts and everything that could be saved to Cloud Save can now be exported to password encrypted files for easy backup / restore (Require unlocker)
- Clicking on the backup file in file explorer, or any cloud provider will directly propose to restore it’s content.
- Menu entries to add now playing, and now playing playlist items to Yatse favorites.
- Menu entry to see PVR recording information.
- Ratings are now visible in grid view for movies/shows/episodes.
- Removed translations that are less than 50% complete. Translations are crowd sourced, please join translation site to help finish them.
- Reduce priority of some background things to improve UI performance on older devices.
- Update the gesture pad to fix some issues and add repeat mode visual indicator.
- Quick fix to recognize JellyFin 10.x and Emby 4.x versions
- Many details fixes and optimizations.
I downloaded Yatse on my Android then purchased the Unlocker to be able to fully use it, but I can not get it to log into my Plex server. I login to Plex.TV using my Google account. No matter how I’ve tried to format it in Yatse it says wrong username or password. Can you please tell me how to get logged in so I can use the app?
I already answered you 7 days ago about what I need to be able to help you.
Asking the exact same question here will lead to the exact same answer
At least you give one more clue that you are using a Google login and not normal login, so issue can be tied to that.
Add a Plex Password to a Google or Facebook Account
If you first started using Plex with your Google or Facebook account, you don’t have a Plex password. You can add a regular password to your account at any time. This allows signing in to the Plex account without Google or Facebook, using the account email address and password.
- Sign in to the Plex web app.
- Visit your Plex account page.
- In the Password section, you should see Not set , showing that you do not have a password yet.
- On the Accounts tab, click the Edit link the Password section.
- Enter your new account password (be sure to choose a strong, unique one!) and then confirm it.
- Click the Save Changes button.
You can now sign in to your account using a password by choosing Continue with Email on any Plex login page.
Yatse 8.9.0 released.
Important: After the result of Android 4.X usage survey, this is the latest version to support Android 4.x.
- Added: Favourites support for library items. Set media items as favourites, filter on them and sort them first (Configurable in settings).
- Added: Smart filters now support audio codec/channels and video codec/height/width for easy filtering by quality.
- Added: Sleep timer. Stop currently playing media/queue after a delay, accessible from now playing 3 dots.
- Added: You can now export and import custom commands to files for easy sharing. (Unlocker only) (Do not hesitate to use the forum to share useful commands)
- Added: Duplicate custom commands.
- Changed: Small changes to left menu design.
- Fixed: Remove some Kodi internal Curl params when migrating streams from Kodi to other players.
- Fixed: Quick settings tiles on Android 9.
- Fixed: Improve volume handling of local player when out of Yatse on some devices.
- Fixed: Fixed custom commands image quality on some devices when assigned to remote screen.
- Fixed: Possible streaming stop when remote players takes time to load items in a queue.
- Fixed: Many details fixes and optimizations.
Would love to have playlists implemented i don’t know if that’s a feature bieng worked on but I can cross my fingers
It’s high on the TODO now that Kodi 18 is out.
But be aware that there’s an high chance that that editing Plex playlist from Yatse will not be present in first iteration. (But probably import them on Yatse then edit them on Yatse).
Limitation caused by Kodi limited API.
Press the like button at that feature
And do not hesitate to make others.
Yatse 9.0.0 released
Important: Yatse is now an Android 5+ application, allowing simpler maintenance, with faster and smaller app.
Previous version will stay on Play Store so that users of Android 4.x can still reinstall without issues.
This release is a major one to fully embrace Android 5+, unfortunately it is possible that some manufacturers had bug on some old Android 5.x devices, please report any issues to support with details on your device.
- Lyrics display on the phone when playing on Kodi and having CU Lyrics plugin enabled.
- Directors and writers can now be clicked to show all media directed or written by those persons.
- Smart filters on date added and last played for always more powerful and versatile filtering.
- Support for premiered field for movies for a more accurate sorting by Year. (Require Kodi 17+)
- New option to have +30s / -30s buttons in notification instead of next/previous.
- Better grouped movie set ordering when ordering by Year.
- Fixed Infinite syncs when Emby returns some invalid data.
- Prevent multiple click on export / import settings buttons.
- Some dialogs now report proper %WIN value in tasker.
Yatse 9.1.5 released.
- Seek from notification in Android Q beta 2.
- Support embedded music images for local device music library.
- Library favorites are now synced with Emby/Jellyfin server.
- Configurable delay for picture slideshows.
- AI voice commands for Italian language.
- Stop debug mode from left menu and easier issue reporting from Help / About.
- Jellyfin is now a first class client with dedicated add entry and icons.
- Migrated AI voice agent to new API, recognition success can be lower for a few days until agent trains a little.
- Tweaking of now playing design for music.
- Fixed edge case where image cache folder was reset after a restart.
- Add support for Jellyfin 10.3 new authentication
Yatse 9.1.7 is released.
- Support for %currenthostname% place holder to HTTP Custom command plugin and extend usage of place holders to most fields.
- New option to Tasker plugin renderer change command to allow migrating currently playing media and playlist.
- Fixed PVR support for Emby 4.x.
- Workaround to another Kodi PVR API issue with recordings thumbnails.
- Fixed a race condition on some devices with tasker plugin preventing proper notification channels to be created.
Yatse 9.2.0 is released
- Complete rewrite of download manager. Download queue now survive app kills, can work independently of the active Media Center and support configurable simultaneous downloads.
- Major update of UPnP library, please report any UPnP/DLNA issues.
- Use new more aggressive compilation options, as usual please report any crash or issues to support.
- Fixed Emby favorites sync for artists.
- Fixed Smart sync issue with removed synced artist.
- Better support of plugin reconnection when they are killed by bad OEM Android.
Yatse 9.2.5 is released
- Compiled and targeted for Android Q with the first wave of necessary changes. Everything should still work the same or better, but as usual please report issues to support.
- Optimisations to internal audio player to reduce application size, if some exotic files no more plays, please contact support with details.
- You can now set custom commands to be host specific, allowing the same button to be mapped to different commands for each hosts.
- Bengali translation thanks to A. Junayeed.
- Removed Bulgarian, Greek, Portuguese (Portugal), Danish, Ukrainian, Catalan and Lithuanian translations as too incomplete or low quality. Please use translation website to help and bring them back.
- Fixed collection art for Plex.
- Fixed some UPnP discovery issues.
- Fix watched status sometimes not updated when playing offline with VLC.
Yatse 9.2.7 is released
- Many Google libraries updates (generating a tons of internal rewrites) to continue preparation for Android Q new functions, please report any issues to support.
- Rewrote the drag and drop code used for reordering playlist and custom commands, please report issues as it will serve as an important base for the upcoming functions.
- Added back Catalan translation thanks to Xavier R.
- New option to not sync empty shows (On by default)
- Fixed many small transition details.
- Fixed some more UPnP discovery issues.
Yatse 9.3.0 is released
- Last large bunch of internal changes for now, return of bigger new features after the holidays
(Do not forget to make feature requests if they are not already on the website). - New host information dialog to see database media counts. (Accessible from host icon in left menu and 3 dots menu in hosts lists)
- Many new text fields can be selected for copy/paste.
- Google search button for cast.
- Added back Ukrainian translation thanks to AndriiZ.
- Fixed some issues with writers/directors.
- Fixed favorites for local device library items where lost on sync.
- Fixed some more UPnP things, if you have any issue contact support with logs, some devices do not respect standard but often workarounds can be created with your help.
On a shield TV is Yatse supposed to control Plex and start films through the app or just read my Plex info and then cast it through the built in chrome cast feature? I can only seam to get it to work this way but then I only get standard 2.0 audio.
For the moment it does not control clients directly as there was no ask for that.
It’s on the todo list after playlists support that should come not so far away.
You can enable AC3 / EAC3 support when casting to Chromecast in the settings (General / Advanced).
Please open feature requests on https://community.yatse.tv/ so I can priorize Plex more as interest is growing, many details are missing due to lack of support in Kodi and Kodi being the smallest denominator.
The more people asks the more Plex support will be extended faster.
