You Are Not Authorized (?)
Problem Review and Solution Summary:
I initialized a new NAS server (QNAP TS-464U) which I then installed Plex on. After setting it up on my network, I attempted to login to Plex. I succeeded, but was then directed to a page which indicated I was not authorized and had to claim the server.
  • I did not have the option to claim it locally.
  • Logging into my Plex.TV account did not permit claim.
  • SSH tunneling did not permit me to utilize the loopback to claim.
Ultimately, the solution was to SSH in and utilize the UserCredentialReset bash script (linked further down) combined with a paired key from plex.tv/claim to force the server to update.
Thank you @ChuckPa for your timely and helpful troubleshooting.
are you saying:
ssh  -L 8888:127.0.0.1:32400  ip.addr.of.qnap
will not then allow you to open up
http://127.0.0.1:8888/web
on your computer?
Yes.
ssh -L 8888:127.0.0.1:32400 10.20.30.40
ssh: connect to host 10.20.30.40 port 22: Connection refused
The SSH server is not enabled.
Oh, sorry! Forgot I shut it off to test something else.
Corrupted MAC on input.
ssh_dispatch_run_fatal: Connection to 10.20.30.40 port 22: message authentication code incorrect
You have encryption / encapsulation with other SSH protocol defined or active?
What you’re showing only happens when the default protocols get changed.
I did not modify anything related to encryption. The only thing I could think of would be that I trunked the two ethernet ports together.
I was able to get it working via:
ssh -m hmac-sha2-512 -L 8888:127.0.0.1:32400 10.20.30.40
Having said that, browsing to 127.0.0.1:8888 does nothing.
The connection was reset
The connection to the server was reset while the page was loading.
i was just looking that up for you:
-m hmac-sha2-256
followed by
[chuck@lizum ~.2002]$ ssh -Q mac
hmac-sha1
hmac-sha1-96
hmac-sha2-256
hmac-sha2-512
hmac-md5
hmac-md5-96
umac-64@openssh.com
umac-128@openssh.com
hmac-sha1-etm@openssh.com
hmac-sha1-96-etm@openssh.com
hmac-sha2-256-etm@openssh.com
hmac-sha2-512-etm@openssh.com
hmac-md5-etm@openssh.com
hmac-md5-96-etm@openssh.com
umac-64-etm@openssh.com
umac-128-etm@openssh.com
[chuck@lizum ~.2003]$
Don’t browse to 32400. There is no 32400 port on your computer.
You want http://127.0.0.1:8888/web (go through the SSH tunnel port)
Sorry about that- that was a typo- my hands were moving faster than my brain.
Browsing to localhost:8888 leads to the connect reset error I mentioned.
Here we go… Checking the output on the tunnel and seeing the following:
channel 3: open failed: administratively prohibited: open failed
Repeating ad nauseum.
ok… time to get mean.
  1. go here and download the 'UserCredentialReset.sh` script
    — I have documentation / examples in the README.md
  2. Upload to the Public share on the QNAP
  3. chmod +x /share/Public/UserCredentialReset.sh
  4. /share/Public/UserCredentialReset.sh
It will ask for a claim token.
  1. In another tab, open https://plex.tv/claim
  2. COPY it
  3. Return to the SSH session and paste the claim-xxxxx token
  4. Hit enter.
  5. If the QNAP has internet connectivity, it will get new credentials from Plex.tv and claim your server for you
That’s done it- cheers, mate.
I will just say this post right here saved me ripping the rest of my hair out, thank you very much.
