Server version: 1.24.2.4973
OS: QNAP, TS-231P, OS Version 4.5.4.1741
Clients, w/ versions, if applicable: tvOS
What you did?
Installed Plex Media Server.
What happened?
Launching the PMS app on the QNAP web-GUI attempts to open the first-time-setup page (http://10.30.0.10:32400/web/index.html#!/setup/e9038bfcd0751ab900ff247c4940c314cf041499). Opening this page results in a “NOT AUTHORIZED, You do not have access to this server”. I cannot complete any basic setup and therefore cannot add any media sources. Going to the main Plex web-GUI asks me to install PMS, which is hilarious because it’s the PMS itself that’s showing me this page.
What you expected?
To be able to run the basic setup and use Plex.
Detailed information.
Plex Media Server 1.16 was previously installed on this NAS. A reinstall was necessary due to upgrading the QNAP OS multiple times, which for whatever reason rendered my Plex server unable to read my media sources. I upgraded to PMS v1.24.2 and wanted to start fresh.
Upon opening my Plex app using the QNAP icon, it asked me to log in. I used my normal Plex account with a premium sub, which logged in fine, however it took me to the home page where my media sources normally would be. I cannot add any sources because it thinks I do not have PMS installed.
Upon clicking the QNAP Plex icon again, I noticed it was taking me to the first-time setup page in which you’d configure the sever so you can add media sources. This is where the “NOT AUTHORIZED” page comes into effect. I can not complete basic setup, so I cannot use PMS.
I’ve attempted many ways to remedy this:
- Re-install PMS using the QNAP App Store. Doesn’t work.
- Manually remove PMS from “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer”. Doesn’t work.
- Uninstall PMS using the “.uninstall.sh” script from within “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer”. Doesn’t work.
- Attempt all methods above, but log out of the app before uninstalling, then restart the NAS before installing again. Doesn’t work.
- Remove all clients from “Authorized Devices” page, then log out/in. Doesn’t work.
- Remove all QNAP and Plex related browser cookies, then attempt manual uninstall/re-install. Doesn’t work.
In all attempts above, the same behaviour occurs. Upon re-installing PMS, it doesn’t not ask me to log back in, so user credentials are being cached/stored somewhere on the QNAP outside the .qpkg/PlexMediaServer app install directory. I believe this is the crux of the problem and old files are being stored somewhere within my QNAP that don’t get removed when uninstalling the app. If anyone knows where these files are located that would be fantastic, because I’ve not found any answers on the Plex forums or anywhere else yet. If anyone knows another solution that would be welcome too.
