I recently accidentally changed my TV Shows agent to “Personal Media Shows”, so I quickly tried to change it back to “Plex TV Shows”, but every time I try, Plex gives me the error “Your changes could not be saved”. I have tried rebooting the server but this didn’t seem to change anything. Changing the visibility settings seems to save properly but the library still doesn’t show up in the Home Screen afterwards. I am pretty sure no scans are going on, so I’m not sure what to do to fix this.
Also, now when I try to go to “Live TV & DVR” it just gives me a nonspecific “There was an unexpected error” message. I’m worried something has been corrupted.
Agent settings won’t prevent you from changing them back; Internet connectivity and CURL errors will block it. (Plex.tv maintains your agent settings to aid in retrieving metadata for you)
If the server can’t communicate to plex.tv, it won’t be able to save the settings changes.
The certificate on the account is valid:
Thu, 18 Nov 2021 19:14:13 +0000 Thu, 18 Nov 2021 19:14:22 +0000
There is a certificate issue in there somewhere. FQDN https access address ? Proxy? modem/router? something
Please consider bonding the adapter first and restarting Plex. That’s a better configuration anyway … it’s compliant with TCP/IP networking industry standards too.
Nope, I’m still seeing the error where it won’t let me change the agent
This is only happening with the TV Shows library where I accidentally changed the agent - all of the other libraries are working fine. Is there any way I can manually force this change back?
Oh I think I solved it! All I needed to do is change the agent specifically to TheTVDB, and then changed it to Plex TV Series, and it worked this time!
