So I think i figured it out, I did a ipconfig /flusdns and then did the procedure mentioned above(Plex won’t start normally after a clean reinstall and is stuck on getting ready) then ran the html file from the plex data folder and everything came back, so maybe it was a bad dns route. Thanks again for all of your help!
Thank you for getting back and telling your solution!
It will be quite valuable for other users with the same issue.
