0.1.39, first impressions
Thanks to the Rasplex team for this new release. Your work is very much appreciated.
0.1.39 seems to be a bit snappier. The main problem is still when you enter sections, where is takes too long to get through. Navigation inside sections is getting better...more then acceptable. Video playback flawless....this is in fact the most impressive part of Rasplex.
Another problem is I loose parts of my configuration, for example the default view mode in sections always comes back. This seems to be a global Plex Home Theater problem since I have the same issue on a Ubuntu installation.
Even if three is room for progress, I use Rasplex as my main media player...over LG Medialink wich is snappier, but does'nt permit me to change audio language or choose subtitles in .mkv files.
A change log of 0.1.39 would be appreciated. Thanks again for good work.
I’m excited to try out the new release.
Just a short remark: 0.1.39 has a wifi issue (the key won't be saved). Please still use 0.1.37 if you're relying on wifi.
Please use 0.1.40.
Closing this topic.
