1.20.1.3252 Nightly segfault
Server Version#: 1.20.1.3252
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name:
Device: WD PR4100
Three nights in a row now Plex has crashed at almost the exact same time. At this time recodings are happening, which then fail, but there is zero interaction with any clients.
Has anyone else experience this?
What I see is tens of thousands of lines of guide data operations, which is strange because the nightly operation is set to happen at 5am and my crashes are happening within two minutes of midnight. So, why is my nightly maintenance operation happening at midnight instead of five am? Does that for some reason go off UTC time and not local time? I’ve now disabled most of what Plex does during this maintenance as I can no longer trust Plex to not crash again and cease recordings.
I only have the last two, I believe the third was the same. These are happening at the exact same memory location in Plex each night.
[Mon Sep 14 00:01:47 2020] Plex Media Serv[20636]: segfault at 120 ip 00000000010a8db9 sp 00007ff2c7a22600 error 4 in Plex Media Server[96f000+e1b000]
[Tue Sep 15 00:01:33 2020] Plex Media Serv[4862]: segfault at 120 ip 00000000010a8db9 sp 00007fe360b43600 error 4 in Plex Media Server[96f000+e1b000]
I’m not including any logs because every single night the crash uploader says it submitted them. So you must just look up my account and get them there if anyone actually cares.
FOUR nights in a row.
[Wed Sep 16 00:01:39 2020] Plex Media Serv[902]: segfault at 120 ip 00000000010a8db9 sp 00007f4ebab7c600 error 4 in Plex Media Server[96f000+e1b000]
The only thing plex was doing was recording an SD channel with a couple minutes of overlap in each direction.
In scheduled tasks I have "Perform refresh of program guide data. " explicitly unchecked. Yet still right around midnight this process fired up again…
Like clockwork. FIVE nights in a row.
[Thu Sep 17 00:01:43 2020] Plex Media Serv[7751]: segfault at 120 ip 00000000010a8db9 sp 00007ff519cd6600 error 4 in Plex Media Server[96f000+e1b000]
Again at the exact same spot.
I have a feeling it’s something about “The Powerpuff Girls (1998)” that is making plex s***.
It would sure be nice if someone at plex even cared.
