Hello- In my library, I have 2 shows by the same name. Still Standing, 1 is the American Sitcom from the 90s, and the other is the Canadian reality show. I’ve tried to distinguish the 2 by calling the
Canadian Show “SS Canada” but it will only show up in Plex under folder view. Is there a way to fix this issue or am I stuck? Thanks.
Canadian show: try Still Sanding (2015) as a folder name for the series
American show : try Still Standing (2002) as folder name.
You can also add a reference to the TVDB or TMDB in curly braces: to help Plex out:
Still Standing (2015) {tmdb-66922} or Still Standing (2015) {tvdb-297219}
Still Standing (2002) {tmdb-402} or Still Standing (2002) {tvdb-70692}
EDIT: you might have to Plex Dance the Canadian show to get it to show properly after you change the folder name.
THANK YOU!! Renaming these shows with the years afterwards worked!! THANK YOU!!!
I have one other question you may be able to help with- when I want to play all episodes, how come plex gets hung up after certain episodes, then I have to push play on my remote to get the episodes to start up again? Is there some way the videos begin that hangs up plex?
