3P Plex Audio Player for Samsung Galaxy Watch (Tizen)
I would also like to be part of the beta.
Looks really well designed and polished so far, but the music is a little choppy when I don’t have the watch on and the app in focus. I have the Mifo O5 bluetooth headphones and the Gear Sport. I have WiFi enabled on the watch and it’s connected to my phone which is a Galaxy S8+. Is there any way to help by sending logs or anything? What more information would you need to debug? Also, at first I couldn’t connect to my main server and the other server doesn’t have any music and when I selected that server the app wouldn’t let me select the options to change the server until I went back to switch users and logged into my user again. So far I’m very impressed though! :grin:
Hey,
Thanks for the feedback.
One problem I am in conversation with Samsung about is what is called SAP. SAP (Samsung Accessory Protocol) is how the phone communicates with the watch and vice versa. Any network connection established from your watch, while you are connected via SAP, will go through SAP even if you have WiFi on. This means that the audio will be streamed to the watch via BT, which has quite limited bandwidth (particularly if you are using BTLE).
When in SAP mode, the WearPlex app will request a 96kbps stream from your Plex transcoder service. You can tell what bitrate the audio is from the player screen. There will be an icon indicating it. If the bitrate is higher than 96k, then that would explain the jitter, as it will likely be buffering. If it is 96k, then it could point a lot BT congestion or your transcoder is unable to keep up (which is probably unlikely), or some other issue. Would you mind describing your setup?
What you could try is disconnecting the watch from the Samsung Galaxy Wearable app. You can do this from within the App itself. Once it is disconnected, you will notice the SAP icon, on the player screen, fade away. If you start playing a new track, it should then attempt a direct play session, and the skipping should go away.
Let me know if that helps?
I’ve installed the Beta, and am able to log in to my Plex server, however once the watch logs in, it does not show any content, just the ā€œNothing to see here!ā€
What sort of info do you need? I’ve got a 46mm LTE, SM-R805F (Australia)
Software Version: R805FXXU1ESE3/R805FOXX1ESE3/R805FXXU1ESE3
Do you have any playlists setup? At the moment, you are only able to see audio playlists you have created. There are plans to allow you to access audio by Artists, Album, etc… But because of the form factor, I have focused on Playlists initially. This functionality will be available after I have completed the sync/downloads feature.
Sorry… I guessed t would have been something obvious. Should’ve read the thread properly, just a little too excited :slight_smile:
Just tried disconnecting the phone but still a bit choppy, but that may be a wifi limitation at work.
Hi is still available, can I try it please is well.
Just have watch and need connect then to home server and listen music when I’m work.
Hey man, I’m keen to try out the beta, can you please give me an invite? Cheers.
Can i be part of the beta?
Great job my friend! I don’t have the watch yet but planning on getting it in the new year. Looking forward to navigating albums.
Hi, I 've just got the watch. Is it still possible to try your app?
Hi, like many others, just got the watch and i would be delighted to try the beta and participate in any form to the dev/bug report. Thank you very much to give this app your time, i’m sure it will sell great! :slight_smile:
Hey, Ive got new active 2 and I’m plex lifetime Subscriber. Is it possible to try the new beta app?
Same goes for me : Active2 and Plex member so would like to get this app.
Yeah I’d love to try the app too, it looks great. Can I get an invite?
Hi All.
I am about to do an onboarding for the beta, before I pickup from where I left off.
For those who aren’t part of the beta and want to be in, can you PM me the email address you have assigned to your Samsung Galaxy Store account? I will get you onboarded as soon as I have it.
I would also like to join the test.
Would love to… As I indicated in the post above yours, I need your samsung account email address.
I have added you to the beta. I suggest you edit or delete your post with your email before it gets scraped.
@silmagor_mail_ru: Here is beta access url: http://apps.samsung.com/betastore/appDetail.as?appId=bEehVEou6L. Go there on your watched parent device, and you will be directed to install it.
Hello, pics look great but beta is closed. When can i use the app or join the beta.
