Here’s the latest run of logs after the second attempt to install the latest update;
download_2019-04-24_18-07-06.zip (13.8 MB)
So much for having the day off… let me know how I can give feedback to your supervisor…
Same here…I REALLY appreciate this. I have about 50 soldiers who will appreciate it as well. “If” I can get this working, that is? LOL!
Sorry for delay.
I had ordered dinner for family & had to pick it up.
Restart of the system doesn’t help?
Signing the browser out, flushing its cache, opening ip again, IN INCOGNITO WINDOW also of no help
worst-case scenario plan: Install the previous on top of what’s there. Go back to what works until whatever is going on gets sorted out.
No, unfortunately, I’ve tried everything except restarting the QNAP (since that takes forever +10 years). Do the new logs show the same failure to install the resources?
FWIW, when I installed the last known working version 1.15.3.858 is when it generated the log you initially looked at. And since it too didn’t work, I’m literally hosed.
Which browser is being used to access and which OS?
Also, please grab another set of logs manually from the QNAP. Let’s see what changed
Two PCs.
PC 1 is remote but accessing Plex server LAN via VPN. Running Windows 7 with Brave (both regular and incognito)
PC 2 is a local PC on the same LAN as server. Running Windows 10. Chrome. Incognito and regular.
Latest log after installing most current QPKG file is a couple posts up… heres a link to it:
https://global.discourse-cdn.com/plex/original/3X/b/c/bcb8fb162af2e6178f26d6474cb0a07222f7e9fc.zip
For laughs, because the latest chrome is funky even for me, hit it once with FireFox.
Trying now… Says “waiting for connection” in the status bar. Oddly enough, none of the tabs I’ve tried so far ever actually time out. They seem to perpetually wait.
Reboot required sadly. Brace for impact.
Apr 24, 2019 18:02:45.194 [0x7f3d8cbe7700] DEBUG - HTTP requesting GET https://plex.tv/api/codecs/libx264_encoder?build=linux-x86_64-standard&deviceId=6612be8c-00f5-4970-90b9-cbb517ed4acb&oldestPreviousVersion=1%2E15%2E3%2E858-fbfb913f7&version=392df4f-2183
Apr 24, 2019 18:02:45.210 [0x7f3d99edf740] ERROR - HttpServer: Error binding acceptor: Address already in use
Apr 24, 2019 18:02:45.210 [0x7f3d99edf740] ERROR - Error: Unable to set up server: listen: Address already in use (N5boost16exception_detail10clone_implINS0_19error_info_injectorINS_6system12system_errorEEEEE
Socket 32400 is stuck open / already in use
AHH!! Ok, I’ll report back next year
Go enjoy your cold dinner. How do we send word to your supervisor?
just send a note via plex.tv if you want.
FYI ? My TVS-1282-i7 is just as slow. Pathetic!
Consider it done. I appreciate you. Not too many employees go the extra mile any more.
ANy suggestions for me?
same please.
Try the reboot & fall back to previous.
How is the LAN at IPv4 ? no improvements?
Nada…but thanks. It’s 3 AM here (Kandahar, Afghanistan)…just trying to get my soldiers some entertainment. Thanks for your efforts!
Thanks for your service! Stay safe. Mine is still in the process of shutting down. I’ll post back results here.
I will be here. I am preparing MRE replacements should there be need.
(they’ve been rejected at least twice already — All will be good)
Yeah, I hear ya. But, the guys were happy until 2 PM today and you should have seen the call log I had. They are just coming in (new rotation) and this was something that kept them kinda distracted from them being away from home. It may sound cliche, but, I care for my soldiers and their well being.
