I updated PMS to 1.25.1 last week, but after that I’m not able anymore to open PMS in the web interface, I get an 404 Page not Found error. Rolling back to 1.25.0 fixed it again but after that I no longer have access to the server settings.
Tried to update to 1.25.2 today, but again 404 page not found when trying to reach the server through the browser.
Clients on mobile devices are still working in this state on the new server versions.
Anyone have any idea?
I already had the PlexData share, so this was working already.
Did as you asked, only had some trouble getting the logs through filestation because of access permission issue?, so used SSH instead.
Below are the logs as requested, hope this helps. Logs.zip (3.2 MB)
Dec 08, 2021 22:25:27.719 [0x7fc578216d48] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Dec 08, 2021 22:25:27.719 [0x7fc578216d48] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Dec 08, 2021 22:25:27.719 [0x7fc578216d48] ERROR - HttpServer: Error binding acceptor: Address in use
Dec 08, 2021 22:25:27.719 [0x7fc578216d48] ERROR - HttpServer: Error opening acceptor on IPv6, falling back to IPv4: Address in use
Dec 08, 2021 22:25:27.719 [0x7fc578216d48] ERROR - Error: Unable to set up server: listen: Address in use (N5boost10wrapexceptINS_6system12system_errorEEE)
PMS release 1.25.2.5319 contains the control scripting fix for this.
I’m VERY sorry this type issue slipped through my initial testing.
@ChuckPa
I tried to download 1.25.1 fresh again and installed it. After this I still get the 404 error in the browser. Stopping and restarting PMS in the app center does not work for me also, still receiving the 404 error.
Any other suggestions maybe?
@ChuckPa
[EDIT] Below is the result of this command, killed all the processes in the list as you explained, downloaded and installed PMS 1.25.2, opened PMS and everything is working again!
Thanks for your help!
/share/ZFS532_DATA/.qpkg/PlexMediaServer/Library$ ps -ef | grep -i plex
4220 admin 146680 S ./Plex Media Server
5167 admin 164 S /share/ZFS532_DATA/.qpkg/PlexMediaServer/Plex Tuner Service /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Tuner/Private /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Tuner/Shared 1.25.0.5282-2edd3c44d 32600
7511 admin 38844 S N Plex Plug-in [com.plexapp.system] /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5282-2edd3c44d /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/System.bundle
10195 admin 29552 S Plex Plug-in [tv.plex.agents.movie] /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5282-2edd3c44d /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/PlexMovieNew.bundle
11514 admin 29936 S Plex Plug-in [com.plexapp.agents.plexthememusic] /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5282-2edd3c44d /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/PlexThemeMusic.bundle
11533 admin 31288 S Plex Plug-in [tv.plex.agents.music] /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5282-2edd3c44d /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/PlexMusic.bundle
12686 admin 30312 S Plex Plug-in [com.plexapp.agents.none] /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5282-2edd3c44d /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/PersonalMedia.bundle
13242 admin 37760 S Plex Plug-in [com.plexapp.agents.themoviedb] /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5282-2edd3c44d /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/TheMovieDB.bundle
13348 admin 40380 S Plex Plug-in [com.plexapp.agents.thetvdb] /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.0.5282-2edd3c44d /share/ZFS532_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-2edd3c44d/TheTVDBv4.bundle
23272 admin 288 S Plex EAE Service
30107 Wouter 1144 S grep -i plex
Haha, I’m sure you’re right and know I’d rather not swop places
Still bit curious though, what made my situation “different” from the rest, looking at the entire community.
Thanks again and success with your next patient!
I have this same issue without being able to access or see any of my own libraries/servers in the plex players on my TV nd phone etc. And I get the 404 error trying to open up the settings. I have uninstalled and re-installed but had no luck.
The above sounds like you have a solution but I am not technically proficient enough to know what the SSH Approach is. Any simpleton way of fixing the issue?
Update: I have just seen the new update after posting this question. With hope I installed it, but did not fix. After a NAS restart it did say Plex is still starting up please wait, which was different, but then page not found.
