4K (HEVC Main 10 HDR) on QNAP Plex Media Server
Аnd this is not an argument that both TVs FXW754 and FX780E use the same firmware Version 3.114? How it can be?
More than 80 TVs FX series have the same firmware
LCD models
TX-49FXW584 TX-55FXW584
TX-40FXF687 TX-40FXM655 TX-40FXN688 TX-40FXT686
TX-40FXW654 TX-40FXX689 TX-43FX600E TX-43FX603E
TX-43FX613E TX-43FX620E TX-43FX623E TX-43FX633E
TX-43FXW654 TX-43FXW654S TX-49FX600E TX-49FX603E
TX-49FX613E TX-49FX620E TX-49FX623E TX-49FX633E
TX-49FXF687 TX-49FXM655 TX-49FXN688 TX-49FXT686
TX-49FXW654 TX-49FXW654S TX-49FXX689 TX-55FX600E
TX-55FX603E TX-55FX613E TX-55FX620E TX-55FX623E
TX-55FX633E TX-55FXF687 TX-55FXM655 TX-55FXN688
TX-55FXT686 TX-55FXW654 TX-55FXW654S TX-55FXX689
TX-65FX600E TX-65FX603E TX-65FX620E TX-65FX623E
TX-65FXF687 TX-65FXM655 TX-65FXN688 TX-65FXT686
TX-65FXW654 TX-65FXX689
TX-40FXF737 TX-40FXN738 TX-40FXT736 TX-40FXW724
TX-40FXX739 TX-49FX700E TX-49FXF737 TX-49FXN738
TX-49FXT736 TX-49FXW724 TX-49FXX739 TX-55FX700E
TX-55FXF737 TX-55FXN738 TX-55FXT736 TX-55FXW724
TX-55FXX739 TX-65FX700E TX-65FXW724
TX-43FXW754 TX-49FX740E TX-49FX780E TX-49FXW784
TX-55FX740E TX-55FX780E TX-55FXW784 TX-65FX740E
TX-65FX780E TX-65FXW784 TX-75FX780E TX-75FXW785
and only one TV FXW754 supports PLEX
sad and funny
here is link where the same problem as i have but mentioned TV is from Plex’s LIST Supported
What can you say now?
It has nothing to do with firmware. Plex worked with Panasonic to check if our app worked on their devices. The list we have is what Panasonic told us worked so those are the models we check for. Whether the FXW754 is the same as the FX780E and if our app works on there or not, is not up to Plex to decide. If you think these are the same and Plex should work the same, you’ll need to reach out to Panasonic.
Interesting approach, then I guess it is up to Panasonic on why the Plex is available for “not supported” models?
Also in the other thread Playback issues (Panasonic Smart TV) you can see that it was working just fine before for the users and it started presenting this behavior only after an app update.
And you say that your app is doing this check and enforces the bitrate limitation, why then not add an override switch in the app, I accept any possible issues in my “unsupported model”. Or change the behavior and put a switch on the server side since you anyhow send the model number
The app has always been this way so not sure how an update changed this. That original post sounds like it was a firmware update and not a Plex update.
I’ll bring this up.
So, I called Panasonic technical support in my country. The answer was this: if the Plex application is present in the TV market then it is supported by it and should work. If not ask Plex. If does not work ask Plex. And what to do?
It is “supported” in that the app will play videos, but it’s capabilities will be limited because it is not a model we have specifically tested and confirmed that higher capabilities would work. So something may not as you expect because of these limitations, but the app is actually working as expected since that is how it will work on these devices we have not tested on.
When I came to this forum, I expected to receive technically competent answers to a specific problem, namely: why did plex work before, but after the update it stopped working correctly? what is technically wrong in Panasonic TVs, why are they on the unsupported list? What happened over the last year with the TV and it became unsupported? competent answers are not observed … sorry
Here’s some background. Previously Plex Smart TV apps were available by brand, i.e. Panasonic. The manufacturer then decides which specific models the Plex app will be available on. Plex did not do a check for this, unless specifically asked to. Due to how Smart TV apps work, any manufacturer can choose to allow the Plex app to be made available for their TV even if they did not work directly with Plex. Plex did not want to block these TV’s from having the Plex app, but since they were unsupported the app runs with limited capabilities, since Plex would not know if these TVs would be able to handle codecs like hevc or high bitrates.
Panasonic made a change and told Plex they would only be supporting specific models, so Plex made this change and whitelisted only the models we were told. The list has been mentioned before. Panasonic chose to allow the Plex app to continue running on devices not on the list. Since these are no longer on our whitelist, they run with these limited capabilities. The other option would have been to not have the Plex app anymore.
I correctly understood your message that it was the Plex who decided to limit his functionality for unsupported TVs?
Panasonic smart TV has its own built-in DLNA player that supports hevc and high bitrates. It means that HW and SW of smart TV are ready for it.
3GPP (3rd Generation Partnership Project, .3gp) AVI (Audio Video Interleaved, .avi) Flash Video (.v, .f4v, .f4p, .f4a, .f4b) H.263 H.264 / MPEG-4 Part 10 / AVC video H.265 / MPEG-H Part 2 / HEVC MKV (Matroska Multimedia Container, .mkv .mk3d .mka .mks) QuickTime (.mov, .qt) MP4 (MPEG-4 Part 14, .mp4, .m4a, .m4p, .m4b, .m4r, .m4v) TS (MPEG Transport Stream, .ts, .tsv, .tsa) VP9 VOB (Video Object, .VOB) VRO (DVD-VR, .VRO) WMV (Windows Media Video, .wmv)
Yes.
These players often rely on software decoding for many codecs instead of building it into the hardware. Plex’s app does not have access to these software decoders so it must use hardware. Comparing the DLNA player to Plex is not equivalent.
There’s also other factor besides just the codec and bitrate. Have you tried an hevc file that doesn’t require transcoding. This may just work. For bitrate, have you tried a 50 Mbps or even 100 Mbps file. Some supported TVs even have a limit of 20 Mbps because that’s as high as the manufacturer would support.
When a file is transcoded it uses the DASH protocol as has been mentioned before. The TV may not handle that properly, Plex wouldn’t know. The DLNA player does not need to deal with streaming protocols.
Again, it is Panasonic’s decision on what models are supported. If you think they should support Plex on your TV, you need to talk to Panasonic.
if you immediately admitted that it was you who limited the functionality of the plex for unsupported TVs, I would not distract you over trifles)))))
That’s what I said 15 days ago.
But what I don’t get - when Panasonic provided you with details for its latest generation JZ OLEDs then you know which capabilities (also in view of hardware decoding these models support).
Why does it still say „generic“ in the Plex Dashboard when a movie is played via the Panasonic native Plex app?
Panasonic gave Plex a specific list of series, it does not cover an entire family of products. Is you TV model JZW2004 (OLED) (2021). If it is then there’s a bug and we might not be reading the model number properly. Please enable “send logging to server” in the Plex app on the TV, try to play something, then grab the server logs. Also provide me a screenshot of the about page in the app so I can see what else the TV has identified.
Ok, it’s the JZW1500 which is identical to the JZW2004 (which just has added loudspeakers). If the JZW1500 is not on that list, then this is an error. Can you check if it’s on the list?
It is not on the list. As mentioned, Panasonic provided a specific list. Although the JZW1500 may be similar to the JZW2004, but we check for a specific model number so this will not match.
As I wrote earlier, the list of unsupported Panasonic TVs looks very strange. It looks like there was an error somewhere. You write that such a list was provided to you by Panasonic, which means that you have a connection with them. Is it possible to clarify with them again the list of TV models that support plex, because there are a lot of complaints on the forum regarding Panasonic TVs. Or if it’s not a secret, give their email and we’ll write it ourselves.
We are reviewing your support articles to make sure the TV’s are listed correctly. However, the apps are already following the correct list so nothing will change. I don’t have Panasonic’s email, that’s above my pay grade. You can try contacting them through their website. This is their North American site, which is where I’m located. Official Consumer Product Support - Panasonic USA If you are somewhere else, you will need to find the correct page for your region.
