Installed Plex on a Synology NAS DS415play
Server is up and running.
Acessing from a MAC on an external network using SSH with: ssh -N -D 8080 admin@ipadress
Configured the SOCKS proxy on my MAC to tunnel my connections through the NAS
Acessed “whatsmyip” to confirm that I am acessing through the local network on the NAS and it is wokring.
Plex page loads but STILL it shows: A server could not be found. Download and install Plex Media Server, and it will appear here.
Jesus christ, can someone tell me what the ■■■■ is going wrong? And why the hell would Plex on a NAS require the localhost to connect IF THERE IS NO BROWSER on a NAS?
Even so, I did this whole damn configuration to access it locally and it still doesnt work.
I checked all your guides, but cant find ANY extra instructions. I am loosing my mind here.
Ok. I disabled the proxy configuration in the Mac network settings and logged into SSH using the command you sent (much easier this way, thanks!)!
Still, same problem. Plex webpage doesn’t find any locally installed server. Which makes no sense, since it is accessing the webpage from the server itself, so if plex wasn’t running, that page would not be there.
‘A server could not be found. Download and install Plex Media Server, and it will appear here.’
I went into the synology tool, disabled the server and the webpage stops loading. Re-enabled it, the webpage opens, but it still gives the error. I don’t get it.
Edit: This is coming up in the terminal sometimes
channel 3: open failed: connect failed: Connection refused
channel 4: open failed: connect failed: Connection refused
channel 5: open failed: connect failed: Connection refused
channel 6: open failed: connect failed: Connection refused
channel 7: open failed: connect failed: Connection refused
“Searching for servers…
A server could not be found. Download and install Plex Media Server, and it will appear here.”
I disabled plex on the NAS, accessed the page and it is offline, as expected. Re-enabled it and it loads, but continues not to find the plex server. That’s some weird programming. Why doesn’t the plex webpage load directly? Why am I getting a page that searches for a server?
Is there any other stepp I should be doing before that? It seems my server is not logged to my account, but how do I login if I can’t open the login screen?
This is EVERYTHING I have done so far:
Set up my NAS
Downloaded the NAS version of Plex
Installed the correct plex version on the NAS (I tried all other NAS versions for Synology, none install.)
I am helping my father configure this remotely. I could be that he tried to access it with his email first. But I reinstalled PMS since then. Is there a configuration file I should delete to make sure that it is deleted?
Other than that, I just installed PMS, accessed the webpage, it asks for my email, I used my gmail email and then it arrives at this screen: (/uploads/default/original/3X/e/e/ee79682242278a1cd8353aed64a06de720aaa972.png “”)
Finally found out what the problem was.
The email address I used on my Plex account was not the same email as the Synology’s Admin email. Once I logged in using a Plex account that uses the same email as the synology admin, it found the device and everything worked.
Could say that somewhere in the docs, I lost a whole day on this o_O
Thank you very much for the help @ChuckPA , enjoy your weekend mate!
