"A server could not be found."
Hey guys,
Can’t get Plex to work with Synology.
Visiting my local http://192.168.1.10:32400 shows the Plex interface, but displaying a message:
A server could not be found. Download and install Plex Media Server, and it will appear here.
Tried everything. Uninstall-Reinstall, rebooted Sinology server…nothing helps.
Any ideas?
Alex
Server Version#: PlexMediaServer-1.14.1.5488-cc260c476-x86_64
in an incognito window: http://192.168.1.10:32400/web does not bring you to the Web page?
(needs the /web part)
Yup. It does.
It does, or does not bring you to the Plex/web page and the setup ?
If it loads at all, the server is alive.
It may be locked out. this easily resolved.
Control panel - shared folderrs - give your username R/W access to the Plex share
Stop Plex
Open (in FileStation) Plex / Library / Application Support / Plex Media Server
Delete Preferences.xml
Start Plex
Now open http://ip.addr.of.syno:32400/web again that incognito window.
Be greeted with the signin and Got it window.
Proceed with setup.
Hey, thanks for the info.
I did exactly as you said, step by step.
Still got the same message:
Uh, that’s interesting. I’m having the exact same issue. Tried everything, uninstalled and installed Plex, but ended up with the “server not found” message. It’s totally broken (and btw: I am kind of a system administrator and not a noob). It used to work fine, but stopped working somewhen beginning of march. Also on a Synology DS 415+, used to work with Plex Server 1.13.x, now on the latest stable 1.14.x. Lifetime Plex Pass User.
But I find it very enlightening, that all of a sudden, there are a couple of these posts popping up here, see Plex server unavailable all of a sudden
(edit)
And here: Http://192.168.0.32:32400 cant find server
Wow
Something is up with plex.
I really dunno what to do.
Having same issue generally here. I am noticing that the server actually stops running on my Synology - I restart it on the NAS and it becomes visible again. No reason for it stopping intermittently, that I am able to discern.
Are you guys using FritzBox for your LAN?
that fixed it !! thanks
@trumpy81 thanks. Unfortunately this didn’t work for me:
******** ERROR ********
We failed to authenticate towards plex.tv
Please check username and password, as well as network access
I know that my username and password are correct and I do have network access. Tried the script four times, deleted Preferences.xml and also tried 127.0.0.1 aside the regular internal IP.
yes, all of this, multiple times. I spent two days trying to figure this one out, completely removing Plex and reinstalling. This issue started a couple of days ago even though I didn’t update or change anything, everything went fine before. I feel I’m running out of options :thinking:
sent the log files via pm, cheers for having a look, yay!
Thanks, but unfortunately, I couldn’t fix this issue:
  1. network change: that’s when I restarted everything (rooter and server)
    http 200 is OK, http 401 is unauthorized, so it seems there’s an issue on the plex side of things? Where do you read that my cables are broken?
  2. the server and network cables are fine as there are more services running on various machines and I’m experiencing no other issues. I can download and install packages, the webserver is running fine, I can ssh remotely… The only issue is that Plex cannot find the media server.
  3. Mar 11, 2019 04:05:05 → that’s during the night, when there are some scripts running, requesting a new external IP and servers reboot etc.
  4. I cannot check Plex settings > server, as there is no more server to configure :thinking:
  5. My library is organized nicely, there are just a couple of misplaced files that are coming from iTunes
  6. I removed the damaged video files, but that didn’t change the issue that the server cannot be found (although I can access the web interface)
Thanks for your help though, greatly appreciated!
Ok, I got it working again. Unfortunately I am not sure what was exactly the cause of this issue. I have a FritzBox DSL router and an AirPort Express that is set up in Bridge mode. After disconnecting the AirPort Express and restarting both the FritzBox and the Synology Server, Plex was showing the server again and I could connect it to my account. Now the AirPort Express is in the network again and so far everything seems to work. I am really uncertain if this was the issue, as I did this step at least one time before and it didn’t fix anything. Weird…
Thanks for your help @trumpy81 :beers:
