About remote access
Server Version#: 1.40.4.8679
Player Version#: 4.132.2
I’ve enabled remote sharin of my library but after a few minutes, it turns red
" Not available outside your network"
I belive I configured it right and I don’t understand where or what I did wrong.
Any help would be really welcome
I will add any info that needed to solve this problem.
I have same issue.
This implies your remote access setup isn’t working to begin with. Sadly, Plex will display a green status indicator while it’s testing the remote access status. This test will usually take approximately 20 seconds… however it can also take up to 1-2 minutes under certain circumstances.
Did you already have a look at the related troubleshooting support article?
https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
There’s also a guide with some more details on how to troubleshoot remote access issues. For further assistance you’ll need the individual output/results of those troubleshooting steps.
Have you checked to see if the server is remotely available ? Mine almost always shows the red X despite being available. This is likely due to other network settings that are breaking that feature.
