I can see all the TV shows that I’ve loaded onto Plex from downstairs and I’m logged into the master account, but if I try to play an episode I’m told that I have to spend money to “activate” the player. This does not happen on my SmartTV.
Mobile apps are not free i.e. iOS and Android (unless you have a PlexPass).
I’m using the Windows 10 app. Is that considered to be a mobile app?
Thanks for the quick response, Flanders.
good question actually.
you could also try the older plex media player (it is different than the plex for windows).
I recall that if you download it from here https://www.plex.tv/de/media-server-downloads/#plex-app you don’t have to activate it, while for the app from the windows store this is necessary.
The Windows app store app shouldn’t be available anymore.
I believe the app from the Windows Store was indeed paid for, however I think it is now depreciated.
For the desktop, I would use either Plex for Windows or Plex Media Player (this has a 10ft UI).
