Add Unpin to Home
I know most people love the Home page but I Despise it! (Too often the players default to this)
So plain and simple add the option to Unpin it, like the rest of the menu items…
Hey even if you want/love the Home page why vote against this?
as you can keep it and let the rest of us be free from it?
Thanks,
TMC.
Just to make sure I understand your suggestion… you want to hide the home page and have Plex default to the pinned libraries in your navigation?
That’s not how voting works here… if people don’t like your suggestion, they simply won’t vote for it. No negative votes.
You are correct. it should default to the first pinned library (as they can be reordered).
PLEASE STOP FORCING YOUR HOME SCREEN LANDING ON US.
You wont let us remove it, disable it or set another default PIN INSTEAD. WHY!?$
My default landing should be customized to whatever I decide it to be.
You can simply put a box deep in the advanced settings for us to uncheck to remove home .
WAKE UP and let us customize OUR experience with OUR content on plex OUR WAY.
You have lost touch with us and dropped everything that made plex great in the beginning and turned it into a low budget netflix plutotv hybrid. :nauseated_face: :man_facepalming:
Let’s please focus on the actual suggestion.
As for “turning Plex into a low budget netflix plutotv hybrid” – you can simply disable those online media sources if you don’t like them → https://app.plex.tv/desktop/#!/settings/online-media-sources
In your original thread, others had already pointed out how to customize the home screen. So I suppose what’s left is the focus of this particular suggestion → an option to disable “home” for good.
