Agent/Server settings issues on FreeNAS
Server Version#: 1.15.1.793
Player Version#: 3.83.1
I currently have PMS set up on FreeNAS 11.2-U2.1 as a jail (not iocage). A couple days ago, the agents stopped pulling info/images for movies and shows. When I attempt a manual match, the agent/language drop downs show as “Loading…”. When I attempt to access any server settings, I get “Server settings are unavailable.” Best I can figure, it began when I upgraded to PlexMediaServer-1.15.1.780-a27ffa5be-FreeBSD-amd64.tar.bz2
See post “Scan issue on Plex Media Server Ubuntu” for similar issue on Ubuntu.
Same here.
I was as running FreeBSD 12.0-Rp3 (64-bit) with PLEX version 1.15.1.791-8bec0f76c and had these problems, and then I just barely updated to 1.15.2.793-782228f99 in hopes of a fix. NO luck! I get the same errors:
All “SETTINGS” sections give me “Server settings are unavailable.”
Any attempt to to perform a “Match…” then picking “Search Options” shows “Agent” and “Language” forever stuck as: “Loading…”
Ugh! I should learn to NEVER “upgrade” Plex when it’s working like it should. Release quality control leaves a LOT to be desired, PLEX!
