Agents not working since 1.1.0
Hello,
I wanted to add a Anime to my library and i noticed that none of the agents (TVdb, TMDB, or Plex Movie) doesn’t work anymore.
It is not like the TVdb bug I see in the forum, the Fix Incorrect Match wizard just stay in a weird state with an empty line and the score icon:
I tried to deleted the database, but same.
I tried uninstall PMS and reinstall, same.
Empty plugins cache, same.
I don’t find any errors in the logs.
It’s on FreeBSD 10
Thanks for the help.
I rollbacked to 1.0.0 and now it’s reworking.
I will update later :confused:
same issue. no sign of agents at all, for typical Movie media.
Ok I used the “List of IP addresses and networks that are allowed without auth” as said at https://forums.plex.tv/discussion/comment/1244304/#Comment_1244304 and set “plex server IP”/255.255.255.255 and it’s working now.
I can confirm this has worked for me.
I can confirm it also just worked for me with version 1.2.2
Any idea why?
Thank you! I am on version 1.5.5 on linux and have been struggling with a solution. this works!
