Album radio ignores autoplay
In Plexamp 4.6.2 if you start an Album Radio for an album with no sonically similar albums the album will play and not do.any type of autoplay at the end. Just ends and goes back to main screen.
Guessing album radio expects other albums to be filled in based on sonic info but doesn’t work if sonic info doesn’t exist for a particular album. In this case the autoplay should kick in to keep the queue going.
Hmm, the two things shouldn’t be related at all. Do you see the Autoplay option at the end of the queue? Is it possible your Autoplay setting is such that there aren’t any options either?
The autoplay option is there until the last song in the album starts playing. Then it disappears and the queue just ends after the song is done.
That implies the option selected didn’t produce anything.
I had it set to play track radio for the autoplay option. Track radio works for that song if picked separately so it should have worked.
If I play the album on its own (not via album radio) the autoplay kicks in as expected. So it looks like specific to album radio when no sonically similar albums exist.
Plexamp logs should tell the tale if you can reproduce.
Ok reproduced. Skipped ahead to the last song and let it play out and go back to main screen.
565433918425583.zip (561.7 KB)
Ah, yes…
AutoPlay: Not adding, station
Basically, Autoplay isn’t adding anything because it’s assuming that radio stations can keep generating tracks on their own. We’ll look to fix that in the future.
That’s what I figured. Thanks for looking into it!
