Hey folks, I just bought the Echo Dot today for the specific reason to use it with Plex. I was very disappointed when every single smart device in my house connected with 0 issues. Got to Plex and nope. Alexa just keeps telling me that it can only fine 1 player and that its Safari Web. I have made sure that my PMS is updated as far as it will go. I have removed and enabled the skill about 20 times. The only thing I can think is that for so reason Alexa is trying to use one of my managed user accounts. I noticed that it doesnāt ask me to select which USER when enabling the skill. At this point Im completely lost as to whats wrong. I have 5 different players in my home and I turned on at the same time and started up TV shows on just to see if that would cause Alexa to see them. Still nothing.
ahhhhh okay that worked. Just making sure that the Apple TV was set to the primary account to link it. It seems like something of a design flaw to not be able to use a managed user on that player though. I noticed that it will not control that player at all unless you log into the primary admin account. So for instance, even after I got that as my default player, it wont play anything unless I swap over to the base user account. For most this probably wouldnāt matter, but I have a room mate and we like to swap accounts to keep up with our own individual viewing history and places in certain movies / tv shows.
Same problem. only āseesā Safari player, not Plex player on Samsung TV. All on the same network, all signed into the same account. Verified Plex on Samsung TV is listed in Devices on PMS.
Likewise having issues with Plex for Alexa not seeing my the player on my LG TV even though I can see it just fine in my Devices view and itās signed in using my primary account (same as my server).
Not sure what, if any, logs or debug info might be available to help figure this out, but more than happy to provide whatever I can.
Iām not sure if this will help anyone but Alexa wasnāt seeing a couple of my players either. What I had to do to fix it was make sure that the app was completely logged out of and closed on the device and then start the app up again re-sign in.
This worked for both my PS4 and Fire TV.
This worked for me, thanks a ton! What I did was opened Plex on my Roku, logged out and then restarted my Roku. I then logged back into Plex on my Roku and my Echo immediately found my Roku Plex Player. I havenāt tried this on my ATV4, Fire TV or iDevices, but it worked for my Roku which I primarily use anyway because of the more robust Harmony/Echo integration.
so it looks like most players still are not updated with the support that Alexa app needs (support something called āPubSubā ) to connect and control. this includes all Samsung Tvās using smart hub, so for now this Alexa connection is unusable by a large % of people. ref: https://forums.plex.tv/discussion/256737/alexa-plex#latest
I have updated my PLEXPASS PMS software. Echo dot sees only the browser on my server (PC Tower) and a newly installed T95Z Plus Android Smart Box PLEX client (this will deliver audio from TV Series but NOT from Movies).
I have logged out of my ROKU3 (primary client), rebooted the ROKU, signed back into PLEX and have NO JOY.
This thread may be of some help (look for my post). I have a roku3 and 4 both working great.
@dannyv45 Thanks so much for this; it worked! That being said, this getting old stuff-- dunno-- guess it beats the alternative. Here is where I had a problem: Took me a minute to recall how to unlink the ROKU and then realized that I had to log into my online Roku account. Unlinked the ROKU I wanted to be accessed by Echo Dot. There were so many ādevicesā listed in my PMC Device panel, I deleted most of them paying special attention to the ROKU3 for my TV.
I then re-registered the ROKU3 with my ROKU account naming it a three letter name (as you suggested). On the ROKU page, it displays the name; however, on my PLEX Device page, it is displayed with the serial number of the Roku device-- not my new three letter name. However, Echo Dot found the Roku player listing it by the serial number. SUCCESS!!! THANK YOU!!!
Nonetheless, why isnāt my name change for this device on Rokuās website NOT being reflected on my Device page on Plex? What am I missing? (Thereās that duh, getting old thing happening again!)
One further question: I am a lifetime PLEX PASS member. Everyone-- even remotes-- log in with a password. Currently, is the mesh of Echo Dot and Plex only allowed on the main account?
It sounds like you renamed it on the Roku configuration page but did not delete it from the plex server device page. once you successfully rename it in the roku configuration app you must delete it from the plex server and re-register it into plex.
Regarding your question
The Plex skill is not yet multi user account compatible and must be registered with the main admin user account or it will not work.
My list of what I did could have been done better. From my post: " There were so many ādevicesā listed in my PMC Device panel, I deleted most of them paying special attention to the ROKU3 for my TV."
In viewing some of the posts on the page you linked to, I see discussions of Roku NOT propagating the new name to PLEX devices. Is this still a problem? Checking my PMS Devices page reveals that I still have the serial number.
Ive herd reports of this, but mostly people reported that they did eventually show up it just took a little time (One in particular took 3 hours). I use a ruko 3 and a roku 4 and both showed pretty quickly after the name change and PMS re-register (No more then a minute) after using the method I outlined (I just kept refreshing the PMS browser page until the devices showed up) Maybe try emptying the browser cache.
The Roku device name on the PLEX devices page has finally changed to the three letter name and is recognized by that name by Echo Dot. Will pay closer attention as I install other Echo Dots if / when the interface recognizes users on the PlexPass login. Thanks again for your help!
Having similar issue⦠Iāll ask the skill to play something and itāll go quiet then next time I ask Iām told it canāt find my player anymore. Usually closing plex on the roku and re discovering the devices sorts it out
Happens from time to time
I think that is more of an alexa thing then a plex thing. Iāve not noticed it with plex or my home entertainment system in general but have noticed it with lighting. Iāll ask alexa to turn on living room lights and alexa will activate with spinning blue light for a while and then stop with no response or it will say canāt find device, Then Iāll ask again and it will do the function. I think it has something to do with the echo dot loosing network connectivity for a moment then reconnecting. Next time disconnect the echo and reconnect it (rebooting it) and see if that corrects the issue.
Interesting⦠my lights actually never have issues.
Iām using HUEs
Yesterday Alexa got caught in a spin⦠Iād ask Plex to play something and would just get told the canned ādevice is gone look for another?ā
Iād say no but then it would ask again⦠and again⦠tried to tell it to stop⦠turn off⦠eventually had to unplug
Glad this isnāt hooked into my car⦠You reading this Ford?!
I bought my Echo Dot yesterday, and so far so good. I can get Alexa to list and play items on my Roku3 and the Plex Web App in Firefox and even list items on my Trakt account.
However, I cannot get Alexa to find the Plex for Android app which is running, on the same network, and listed as an āofficially supportedā player.
