Hello @vanstinator and @elan I’m a longtime lifetime Plex Pass member who just bought my first Amazon device (Echo Dot) yesterday. I created a test music library in Plex but I can’t get music to play on the Echo Dot. When I ask Alexa to ask Plex to play a song, Alexa says playing the song but nothing is played.
Remote access is enabled, as it shows “Fully accessible outside your network” in green text. I’m behind a single NAT using a port forwarding rule on 32400.
Alexa says my primary player is Chrome, yet when I ask Alexa to ask Plex to play a song on Chrome, the same silent behavior occurs. Are we also able to play a song in the browser using Alexa? If so, how?
How do I explicitly set the player to the Echo Dot? I read it should default to the Dot, but that’s not happening.
As you know smart speakers, including Alexa, are becoming very popular. Shouldn’t you beef up the Alexa Plex skill integration a bit more in the Plex web interface by including telemetry and diagnostics in the interface? I also feel the Echo devices should appear in the devices interface and also be identified by Alexa as a player. This would certainly add more clarity for your users.
For giggles, I installed the My Media server daemon on my Plex Media Server computer, pointed it to my iTunes music folder, and added the My Media Alexa skill. It worked flawlessly from the start, and I am enjoying my iTunes music on my Echo Dot using Alexa voice control. I didn’t have to open any firewall ports, or do anything to get it to work with the same computer and Echo Dot on the first try. I’m probably comparing apples to oranges, but based upon my failure to get it working and reading issues from other users, Plex Alexa voice integration seems incredibly flaky, overly complex, or dare I say, half-baked in comparison to the My Media solution that I don’t want to use. Why does this other third-party local music streaming server application work with zero effort, but you guys can’t get Plex to work? I hope you put the proper resources into diagnosing and fixing this problem. Now that I think about it, you may actually know what the problem is but can’t or won’t fix it any time soon because it is caused by the design of the Plex cloud architecture.
I am hoping to migrate my music from iTunes to Plex, but this is a definite show stopper. How do I get Alexa voice control working? I’ve spent a lot of time trying to get it to work, and I’d appreciate a heads up as to a solution or if I should quit wasting my time.
Cheers.
