Align 'American Dad!' metadata to TVDB
It appears that the Plex metadata for American Dad! follows the TVDB ordering for the first 13 seasons, but then in season 14 Plex shows 23 episodes:
The 23rd episode ‘Santa, Schmanta’ is actually S15E01 according to TVDB:
https://thetvdb.com/series/american-dad/seasons/official/15
The episode that’s incorrectly labelled:
It has also been discussed by former maintainer of the Tv Rage listing for the show that the TBS-aired seasons contain 22 episodes (as indicated by TVDB).
I appreciate that there has been a lot of stuffing around with the American Dad! season/episode numbers over the years, but the matter seems to now be largely resolved with the exception of Plex. Can this metadata change be made to bring Plex into line with Sonarr/TVDB/TBS/Wikipedia?
You should already be able to set the applicable episode ordering. The default is set on the library level but you can override this for each individual show (:pencil2: > Advanced > Episode ordering).
I’ll mark that as the solution, as it seems there is long-running disparity between TMDB and TVDB when it comes to American Dad!
