Having successfully installed Plexconnect on my two jailbroken ATV2s I thought I'd try it with my ATV3, git was pulled last night.
Everything is working EXCEPT for my Tv Shows section in my library. i.e. Movies section loads and Movies play fine
When I select TV Shows i get "Trailers is unavailable. Try again later"
ATV3
Firmware 6.1.1
DNS server set on ATV: 192.168.1.100
Plexconnect installed on: 192.168.1.100
PMS: 192.168.1.100
PMS and Plexconnect OS: Mac OS X Lion
PlexConnect 0.3.1+
PMS 0.9.9.7
[PlexConnect]
enable_plexgdm = False
ip_pms = 192.168.1.100
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
logpath = .
Any help would be appreciated.
baa
2
Could you please verify if you have access to the file .../PlexConnect/assets/templates/TVSectionTopLevel.xml?
No, I only have .../templates/TVSection.xml
Edit: Just downloaded the rest of the templates using the Git .zip file, strange they weren't there using git pull
Thanks for your help, working now!
