All I had to do to resolve this was update my aTV...
Hey All, so Plex Connect seems to work nicely, It redirects DNS, I can view photos, but as soon as I select a video to watch ATV shows "Trailers is unavailable. Try again later."
All the console reports is;
22:26:52 ATVLogger: loadURL (override): http://atv.plexconnect/library/metadata/6&PlexConnect=MoviePrePlay
22:26:52 WebServer: serving .xml: /library/metadata/6
I tried installing Plex/PlexConnect on a Windows 7 machine but still got the same issue
These details are for the Ubuntu VM
Your ATV model (2 or 3) and firmware version: ATV3 - 5.1 (5201)
The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 10.1.0.55
The device and operating system (including version number) that PlexConnect is installed on: VMWare virtual machine, Ubuntu 12.04
The local IP address of the device that PlexConnect is installed on: 10.1.0.55
The device and operating system (including version number) that the Plex media server (PMS) is installed on: VMWare virtual machine, Ubuntu 12.04 (Same VM)
The Plex media server (PMS) version number you are running (**do not put 'latest'**): 9.8.4.125
The local IP address of the device that the Plex media server (PMS) is installed on: 10.1.0.55
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one.: August 15 - 10am UTC
The content of your 'Settings.cfg' file;
Detail on the media file if it is an issue related to playing a media file:
Media Info - http://pastebin.com/2zyfgyiT
