Analyse process freezes
Server Version#: 1.29.1.6260
Not all my tracks have got the waveform. Initially they had, but I think after moving from M1 to Synology Nas (DS718+) they disappeared.
As yesterday suggested in another topic to re-analyse the library I started with around 550 albums.
I saw when the maintenance tasks started the sonic analysis started. But, after a few hours the scan process freezes at 325 albums to go. It is about 12 hours now it stucks at 325 albums.
So, why does it not proceed? What can I do?
Have you configured your server to only do the sonic analysis during its maintenance window?
If it’s actually stuck you might need to check out the server logs to see if it’s reporting a particular file as corrupted that’s blocking the analysis from progressing.
Thanks @tom80H,
I unchecked mostly everything now in the task settings.
The process started at 12:00 o’clock and it stuck immediately.
In the log files I discovered a corrupted file. After removing the file the process proceeds. I’ll wait and see what happens.
Nevertheless, I think a corrupted file should not stop the process.
After a few hours still no waveforms in the majority of tracks, except the new added albums from the last months.
I decided to do the Plex dance and the process is running now.
