Sonic Analysis Problem
Anyone else every have this problem? Or know how to fix it. This happens every time my music does a scan, it gets stuck in this processing 4 albums loop until the server crashes and I have to reload it. It’s weird, because it scans all the new albums and completes their sonic analysis, then this loop starts.
Never seen this and I know SA can fail in several ways from seeing others’ posts here. But, here is how I fixed my SA problems. If your root problem is also a few bad files this could help. (“Bad” files can check out with every other player and utility, SA can apparently be a little fussy.)
I have tried the suggested fixes in the reply and I am still having the problem. Is there any other way to find the problem files (if that is what it is) in the logs?
Perhaps Plex Media Server - #493 by drzoidberg33
