Ok clearly a teenager or a politician so much talking but so little actually said.
Not many can ignore the laws involving commerce , facts and copy /past posts from 2011 for hardware none uses these days to support a argument that makes no sense.
Well i guess if someone is still using a tv stick from back then running honeycomb and commerce laws got struck down recently he could have a point lol
I guess asking how old you were was kind of pointless you sure went and proved it.
I didn’t i ask you age you age to validate a argument i asked it because of you behavior and postings that have almost nothing to do with facts.
Quoting a sticking from 2011 for hardware that no one actually uses anymore.
Not really getting the irony of that being used to try and further your argument are you?
Of course we got this under powered hardware that capable of 4k playback and has multi cores and multi gpu’s in most cases now.
Yes that same hardware that often benchmarks better the flagships phones and tablets out there today.
Yup really under powered lol
Iam amazed but you constant ability to ignore the facts that plex has run perfect for years now on said under powered boxes and only the recent update caused problems.
But hey iots the under powered crappy boxes…must be of lot of under powered tablets and phones too since the issues be seen affect them too lol.
Arm chair interpretation of the law?
Nope last time i looked you advertise supporting something the law requires you to actually support it. lol
Yes shield tv been supported since it came out because its a android device just like android phones, tablets and these under powered boxes.
The whole official support didn’t become a thing tell everyone saw it pop on there server as a banner announcing it.
I do agree it decent hardware but its not game changing and its nvida jumping into the android box market.
Your are correct in one way there are cheap knock of clones using under powered hardware with crappy support but that’s the same for every maker on the planet these days.
So far it under powered hardware that can do 4k with no optimizations but gets better benchmarks scores then flagship devices and has been running plex fine for five years now.
But hey it has to be the boxes fault it can’t be a plex bug that never happens lol
I asked you age because the only time i seen someone so internet on arguing in other peoples posts when all the facts are saying its likely a programming bug.
I would never tell you or anyone to shut up or the line as your in-titled to you opinion and free speech.
The big give away that you where likely young though was the ignoring of simple hard facts.
The boxes have run perfectly fine for years now with plex.
The hardware capable of 4k with more updates then my 800 dollar phone.
On the matter of hardware last gen doesn’t mean crap so lumping that together probably a bad idea.
You and @danjames92 both ignored those simple facts for the sake of some silly argument.
Occam’s razor: all things being equal the simplest solution is usually correct tell proven otherwise.
The facts as they are is these boxes are :
They run fine on plex for years now without any major issues.
The big names have supported their products better then most flagship android hardware.
The recent update has caused problem beyond merely the android boxes.
By your logic boxes capable of 4k are under powered and the same boxes that have had not major issues in years are the cause.
Logic most people use.
If something is capable of 4k playback its likely not under powered .
A device that’s had no issues for years running a software perfectly fine suddenly has problems with the software after a software is update… for them the simple logical answer is its likely a software bug.
But hey if you want to try and convince people that hardware they been using for years which plex has not had any issues with in all that time is the cause go right ahead.
Me and i am guessing many others are just going to wait for a update to come up with fixes and go back to enjoying plex on are tv boxes/phones and tablets.
