Hi
If you use the Plex app on Android TV with the view mode set to “Library” instead of “Recommended”, after watching something or using the Mark as Played/Unplayed option it doesn’t update in this “Library” view until you navigate to a different library and then navigate back again. Under the “Recommended” view this works fine.
This issue has been outstanding for a long time now, can we get it fixed please?
