Anyone able to get iTunes Plugin working?
Server Version#:4.43.4
New to Plex, but so far love it. The feature to take it over the top would be iTunes integration. Struggling to get the plugin working. iTunes shows up under plugin so that is working. But cant find the music listed anywhere.
Attempting to create a new Library with iTunes import checked, but there is a lot of info last in transition. If I lose playlists, I’m not too worried. Bit ratings are critical. I have a huge library and most is rated.
Anyone get this to work?
Thanks all!
This is really a frustrating topic. I have years into my music library.
