To the left, many recordings failing to finish.
Image taken on a client comp.
Server = Windows 10, virtual comp w/hyper V; windows server 2012 r2
Storage 1 = (initial record storage) Storage Spaces 1TB of SSD
Storage 2 = (final file write) Storage Spaces 17TB of 7200RPM WD Enterprise HDD
Tuner = HDHomeRun Prime x2; one set for Plex, the other for DLNA (yes, I’ve made sure the correct ones are being tuned)
What I end up have happening is many recordings “record” and have “flushed to disk”, but there ends up being no actual recording. They disappear from the file system or are just hung like in the photo. The only thing that fixes it, is when I shutdown the server and start it again. This only works for 3-6 recording events, however. This has been an ongoing issue since July-ish, and was never a problem before. Have been running the same setup since 2014 with no issue. If anyone’s found a work-around or some sort of solution, I’m all for it. Haven’t been able to find anyone with this issue, however, after scouring the plex forums long enough to be a bridge troll…mayhaps I’d become distracted
All help is appreciated,
Cheers!
~P.S.~ I know “Live TV & DVR” haven’t been around since 2014. I used to have a Windows 8 Hyper-V client that would do the actual recording before. Having DVR incorporated into Plex has been a godsend! Turned a 3 machine setup into a single machine workhorse since they released it in Beta.
